Rear disc brake swap questions for my eg hatch
ok, i have a proportion valve , new master cylinder, rear arms calipers, rotors etc froma GSR with all the e brake lines etc, will these work and be a dirrect bolt on for my 1994 eg hatchback? does anybody have any tips, or recommendations much appriciated
Re: Rear disc brake swap questions for my eg hatch (j-D-m)
Since the search isn't working, I'm also interested in this info... Can somebody post a list of what parts are needed.
Also for front GSR brakes, do i need integra knuckles? I have a set of GSR calipers I'd like to reseal and throw on.
Re: Rear disc brake swap questions for my eg hatch (Eyal 951)
All the rear brake parts are direct bolt in swap. Disconnect the trailing arms, the 2 bolts on the upper arm, and the lower arm and drop the whole thing down.
Switch your suspension parts onto the GSR parts and bolt the new stuff back up. While its down might be good idea to add some new bushings if they are worn.
It depends on which MC/PB you got if it will fit. 90-93 RS or 90-95 (i think) are the 15/16" PB/MC that will bolt up and you wont have to bend new lines for. Some others will fit but need new lines bent and others fit at a different angle so the MC doesnt sit verticle. The Disk swap itself should take less than a day though.
Good luck and enjoy the superior stopping power.
Re: Rear disc brake swap questions for my eg hatch (EG_intheworks)
thanks for all the info, can anyone varify the part numbers for the master cylinder that i will need, and will the stock power booster i have work right now work if i keep the stock front discs from my CX hatch, and just swap over the GSR rears? anyone have a picture of the master cylinder that i will need?just want to make sure i have the right one.
It should say 15/16 or 1" on the mc. crv ones work with it also. After swapping, get a wheel alignment done. Just to be sure. hope that helps
Re: Rear disc brake swap questions for my eg hatch (4DeepCivic)
Thanks, hopefully this all goes well. luckily i have changed my whole suspension already, so i have had those lower control arm bolts out, Man, i have had som many problems taking those out on other hondas i have had, it seems liek they lock tight them from the factory?
https://honda-tech.com/zerothread?id=1036267
it's on the top of this forum. make sure u check those before posting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-D-m »</TD></TR><TR><TD CLASS="quote"> and will the stock power booster i have work right now work if i keep the stock front discs from my CX hatch, and just swap over the GSR rears? </TD></TR></TABLE>
you only need the bb/mc upgrade when swapping your front discs. Just dont swap the master cylinder until you have the right brake booster. For the rear, just put in the new proportioning valve when adding the discs. I would suggest doing front and rear at the same time, due to the obligatory alignment when you are done.
Re: Rear disc brake swap questions for my eg hatch (IHateJDM)
anybody have front GSr brakes for sale? i have the master cylinder already, dont wnat it to go to waste, If i swap over the fronts as well, is it that much of a difference in braking power compaired to Stock CX civic hatch front discs, and GSr rears? the car isnt too heavy.
You can expect a decent increase in braking performance. Thats all I will say since i haven't had any first hand experience with it hahah.
EG-SIXV-TEC
10-02-2012 10:58 PM
som3on3_10
03-16-2008 11:55 PM
jus_spooln_wicha
05-12-2007 02:19 PM
Eyal 951
07-31-2006 12:54 AM
