help on installing a fuel pump on a EK!!! ASAP
i need help on installing a brand new fuel pump on a 2000 civic. if anyone has any easier installing tips please let me know. thanks alot
Re: help on installing a fuel pump on a EK!!! ASAP (civics8900)
Well what way do you know. I mean its pretty simple. Remove lower rear seat cushion. Take screws out. Pull pump out. Remove Pump. Reverse directions to reinstall new one. And your done.
Re: help on installing a fuel pump on a EK!!! ASAP (sohcvtec1995)
ight thanks alot. i removed the seat cusion, and the metal plate. there are two round metal cirles under the metal plate, with some screws on it. which one do i pull up. the one closest to the front or the other one.
you pull up the odd shaped metal plate. Then you remove the 8 or 10 10mm bolts that hold the assembly in the tank. The bolts are in a circle btw
Re: help on installing a fuel pump on a EK!!! ASAP (caspers_hatch)
Yea just make sure that you take your time. you dont want to drop in one of those bolts.
Once you get it out, you can see how simple it is. The hose it what holds it in the assembly.
Be glad you don't have a CRX. Those you have to drop the tank....what a ****
