Electrical connector for front headlight problem
Old 08-20-2005, 07:58 PM
badpootie's Avatar
Default Electrical connector for front headlight problem
My 94 EG coupe's front driver side headlight keeps going out every few seconds because the electrical connector is bad. Does anyone here have experience fixing that sort of stuff?
Old 08-22-2005, 04:51 PM
HondaFanatic708's Avatar
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Electrical connector for front headlight problem (badpootie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badpootie &raquo;</TD></TR><TR><TD CLASS="quote">My 94 EG coupe's front driver side headlight keeps going out every few seconds because the electrical connector is bad. Does anyone here have experience fixing that sort of stuff?</TD></TR></TABLE>You could just go to a bone yard and cut one off with a few inches of wire to solder it in...
Old 08-22-2005, 09:18 PM
badpootie's Avatar
Default Re: Electrical connector for front headlight problem (HondaFanatic708)
damn. tools+money=I don't have.
Oh well. I'll see what I can do.
thanks though.
Old 08-23-2005, 05:16 AM
LeonardDB's Avatar
I agree with HondaFanatic708's approach. Slip a 2" piece of electrical shrink tube over the wire after you cut it. After you finish soldering the connection, slip the shrink tube over connection. Use a hair dryer to shrink the shrink tube until it is tight around the connection. If you don't have the tools, one of your friends will. Solder irons are cheap. You can find them at most discount stores.
Old 08-24-2005, 06:08 PM
Default Re: Electrical connector for front headlight problem (LeonardDB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LeonardDB &raquo;</TD></TR><TR><TD CLASS="quote">I agree with HondaFanatic708's approach. Slip a 2" piece of electrical shrink tube over the wire after you cut it. After you finish soldering the connection, slip the shrink tube over connection. Use a hair dryer to shrink the shrink tube until it is tight around the connection. If you don't have the tools, one of your friends will. Solder irons are cheap. You can find them at most discount stores.
</TD></TR></TABLE> Yeah at frys electronics you can pick up a soldering iron and a **** load of solder for under $5..
HondaJack
10
11-09-2006 03:16 PM
Brown-tec
10-29-2006 10:48 AM
CRISIS
01-02-2006 10:03 PM
Dc2 Powered
07-14-2005 08:23 AM
Caveman74
07-28-2003 12:02 PM
Quick Reply: Electrical connector for front headlight problem
