B18C1 bog. Help.
B18C1 bog. Help!!!
I just changed my oil, my car bogs from launch all the way to vtec. vtec kicks very very loud, unusual, but doesn't go anywhere. what can be the problem? mods are skunk2 manifold, dc headers, p30 ecu. I have new sparks and wires. has never happened b4, but i notice time to time would bog right wen i gas the car in first gear, and then it would go away.
hey... unplug your battery positive then negative
to reset the ecu.. wait like 5 minutes then try again. if that doesnt help check your tps and map... also are you throwing a cel?
Re: (1slowcivic)
i have been running awhile with new plugs. my car has been working fine until now. have switch ecu around, doesn't work. i will check my timiing as of now and test a different distributor.
Re: (SpoolinEK9)
I haven't yet put on a different distributor, but planning to wen my friend brings over his integ. atm my car run's like ****, dont want to rev at all. it runs at idle though. dere is also no check engine llight. any other clues?
Re: (bucdenny)
fixed the damn problem!!!! my cat was clogged lol. but one thing, vtec lags like a mother now. bogs wen i hit vtec now. hmmmmmmm any other clues?
Re: (bucdenny)
wen it hits vtec, it jugs then lags on the way to 8k. one thing unusual is the vtec screams like 10 times louder but doens't go anywhere. checked my vtec, the screen is clean no clog at all.
Re: B18C1 bog. Help!!! (bucdenny)
maybe if your cat was clogged that **** out off some other stuff must be clogged too? maybe you got carbon build up like somewhere around your valves? - random guessing lol. why dont you try a can of that fuel injector cleaner. see if it fixes things because thats really weird. everything else works fine till VTEC. maybe one of your cams fell off!!! lmao jk
