Tranny problem need help guys thanks
Guest
Posts: n/a
I changed the clutch release bearing and apparently that wasnt the problem. The transmission fluid had alot of metal particals in it. all the gears work fine, the clutch works fine, it just makes a grinding noise inside the tranny when you start going or are sitting in nuetral with the clutch depressed. It sounds like a bad bearing inside the transmission. Also, will a 92-95 hydro tranny fit without any modifications?
Car is a 1999 civic DX Stock engine.
THANKS
THANKS
Re: Tranny problem need help guys thanks (Aylla)
so your grinding metal, a lot.. i take it.. and your driving.. why not take the tranny out and inspect it yourself.. my guess is grears, bearings, syrchos, all need some lovin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aylla »</TD></TR><TR><TD CLASS="quote">Now that the search feature is working....seems like it could be the input shaft bearing</TD></TR></TABLE> or throw our bearing? anyone?
damn you got a lot of posts
Guest
Posts: n/a
Re: Tranny problem need help guys thanks (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std »</TD></TR><TR><TD CLASS="quote"> or throw out bearing? anyone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aylla »</TD></TR><TR><TD CLASS="quote">I changed the clutch release bearing (throwout bearing) and apparently that wasnt the problem.
Added the bold...but thanks anyways
Guest
Posts: n/a
Damn if i were looking for a replacement what would it be called ? I cant find this ****
Accord15
07-01-2002 04:55 PM
