how to tell cylinder is tdc??
Re: how to tell cylinder is tdc?? (silentbeatz)
An easy way is to stick a long screwdriver or something down into cylinder 1. Obviously the spark plug must be removed. Then spin the crankshaft and you will see the screwdriver go up and down. When the screwdiver is at peak height, your piston is at tdc.
Also there should be marks on your crank pully you could line up which will do the same thing.
Good luck
My first post : )
Good luck
My first post : )
Re: how to tell cylinder is tdc?? (Hondawg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondawg »</TD></TR><TR><TD CLASS="quote">An easy way is to stick a long screwdriver or something down into cylinder 1. Obviously the spark plug must be removed. Then spin the crankshaft and you will see the screwdriver go up and down. When the screwdiver is at peak height, your piston is at tdc.
Good luck
My first post : )</TD></TR></TABLE>
just use the marks.
dont ever stick things into your cylinder.
Good luck
just use the marks.
the screw driver thing works and is a good idea, alot of mechanics will do this just to make sure the marks are right..
mikester1222
02-08-2010 03:57 PM
