suspension problems out of an h22 hatch
i am having problems out of my h22 swap when i hit a hard bump or if i take a turn to hard it sounds like the axles are either rubbing or binding but its not near anything. if i take the suspension down even a few turns on the coilover it does it so bad i can't drive it any help would be appreciated
Re: suspension problems out of an h22 hatch (KTeller8)
what kinda axles and INTERMEDIATE SHAFT too. dont forget that one. and of course lowering your car is never a good thing on your axles
Re: suspension problems out of an h22 hatch (ricerocket05)
the suspension is koni adjustables with ground control coilovers it has a driver side prelude axle passenger side integra and accord intermediate shaft it is a jdm h22 with an m2a4 transmission and the mount kit is hasport thanks again and i hope someone can help
instead of using prelude axles (which i believe it to be your problem) use the 90-93 integra axles.
https://honda-tech.com/zerothread?id=650329
check out that link for more info on your swap
Re: suspension problems out of an h22 hatch (ADVAN EG2)
my h22/eg has hcp mounts with accord intermediate and 90-93 integra axles. My friend have my same configuration but with hasport mounts and he have your same problem.
Both cars are lowered 2.5"+.
Check the axles first, if you still got the problem, blame the mounts.
