Start up and die....
Ok guys the car is a 96 cx hatch with a 00b16 in it i used the cx harness and did all nec wiring.... Car starts up and then will die, but if i give it a little throttle it will run but not smooth. The check engine light is on but when i give it throttle it goes away. I am using a hondata ecu and obd2 to obd1 adapter. the cel is solid but like i said it will go away, and solid usualy means ecu or grounds right?
Re: Start up and die.... (TheYellowDart)
ok guys i have a code 41 headed o2 which is probaly right...... a code 14 iacv and a code 16 fuel injector(s)
for the stalling part... make sure the iacv is plugged in. sounds like its not hooked up so when it goes to idle it just shuts off
Re: Start up and die.... (doublejz)
im not sure bout obd2 cx's but on the obd1 cx's there were only 1 wire o2 sensors and i had to convert to a 4 wire o2 sensor if that helps and yeah i was throwin 41
marcj
12-27-2008 03:50 PM
HXMan
06-01-2001 06:46 AM
