anyone swap a CTR rpm gauge to Si cluster?
HT White Ops
Re: anyone swap a CTR rpm gauge to Si cluster? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">You know it will look different?</TD></TR></TABLE>
Like, really different.
HEH????
I want just the rpm gauge - should be the same as Si but go to 10K (9k on Si) & yes my car will actually see 9.5k
HEH????
HT White Ops
Re: anyone swap a CTR rpm gauge to Si cluster? (_adirondackR_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _adirondackR_ »</TD></TR><TR><TD CLASS="quote">
HEH????
I want just the rpm gauge - should be the same as Si but go to 10K (9k on Si) & yes my car will actually see 9.5k </TD></TR></TABLE>
The face is not the same. The colors and pattern will be different.
Si Cluster
CTR Cluster
The Si face has little gray dots all over it, and has orange needles, as opposed to yellow. It's gonna look like the funk.
HEH????
Si Cluster
CTR Cluster
HT White Ops
Re: (Cboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cboi »</TD></TR><TR><TD CLASS="quote">if ur car is going to see 9.5 would ur car also ever go past 140? </TD></TR></TABLE>
If he road races, then no. If he's hard-*******-core and drags, then maybe, but doubtful.
Re: anyone swap a CTR rpm gauge to Si cluster? (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">The face is not the same. The colors and pattern will be different.
Si Cluster
CTR Cluster
The Si face has little gray dots all over it, and has orange needles, as opposed to yellow. It's gonna look like the funk.</TD></TR></TABLE>
He's right. Why don't you just get a CTR cluster? I would assume finding just a tachometer would be about as easy as hunting down rocking-horse manure.
Si Cluster
CTR Cluster
Re: (Cboi)
ctr is in km/hr.
HT White Ops
Re: anyone swap a CTR rpm gauge to Si cluster? (. a d a m)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . a d a m »</TD></TR><TR><TD CLASS="quote">
He's right. Why don't you just get a CTR cluster? I would assume finding just a tachometer would be about as easy as hunting down rocking-horse manure.</TD></TR></TABLE>
I'll have you know I have a stash of rocking-horse manure in garage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">I'll have you know I have a stash of rocking-horse manure in garage.</TD></TR></TABLE>
Do you? You should post pics of it in the rare parts thread
HT White Ops
Do you? You should post pics of it in the rare parts thread </TD></TR></TABLE>
I'm lying. It's just mulch. I know, it's knockoff rocking-horse manure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">The Si face has little gray dots all over it, and has orange needles, as opposed to yellow. It's gonna look like the funk.</TD></TR></TABLE>
I would still swap it if I could swap the si needle
I have '06 fg2 si seats - which is why I am partial to si cluster - I also want mph
edit: I don't like yellow needles either
this vid is way back when I was 220/155 I am at 230/166 now & cams w/adj exh cam gear are going in shortly. I have a mod'd oil pump good for 9k+ too
http://videos.streetfire.net/s...3.htm just watch 1st min
Modified by _adirondackR_ at 10:29 PM 2/4/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">I'm lying. It's just mulch. I know, it's knockoff rocking-horse manure.</TD></TR></TABLE>
Cmon man, don't fake the funk. Rota-rocking-horse manure ftl
May see 9.5K but it probably wont' reach 150 in the QM.
If it does then you shouldn't need a cluster b/c it should be a gutted car .
My car can see 9.5 too.
Yeah, all I g2 do is put it up to 100 then slap it into 2nd and pop the clutch, bit of wheel spin, but it'll be at 30k RPM or so in the 1/5 of a second before it blows up.
I don't advise doing this. You'll end up breaking the needles. I know I did, and I've removed needles from speedometers before. Seems like the needle on the tach is more stuck onto the pin than the speedometer needle.
I don't advise doing this. You'll end up breaking the needles. I know I did, and I've removed needles from speedometers before. Seems like the needle on the tach is more stuck onto the pin than the speedometer needle.</TD></TR></TABLE>
dammit - i am gonna try anyways - might try a lil heat on the si tach & I don't care if I break the CTR one
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">My car can see 9.5 too.
Yeah, all I g2 do is put it up to 100 then slap it into 2nd and pop the clutch, bit of wheel spin, but it'll be at 30k RPM or so in the 1/5 of a second before it blows up.</TD></TR></TABLE>
omg... lol.... syndacate, that has to be your best post ever....
Re: (_adirondackR_)
does anyone have the tach from a spoon cluster b/c my car is going to 11K but i just hate seeing km/h ...................just swap the whole damn cluster
Re: (Initial Dizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Initial Dizzle »</TD></TR><TR><TD CLASS="quote">does anyone have the tach from a spoon cluster b/c my car is going to 11K but i just hate seeing km/h ...................just swap the whole damn cluster</TD></TR></TABLE>
FU[/B]CK NO!!!! yellow needles km/h - would you like to build my car for me?
SI ('06) SEATS in my ek
SI CLUSTER in my ek
/period
SI CLUSTER in my ek
/period
