Help car won't start!!
Ok, so I can't find my old thread becuase honda-tech is crazy with new topic's. I have a 1992 Civic LX and I recently swapped a D16Z6 (freshly built) into it. Stock harness and everything. I replaced my starter becuase after trying to start it once I thought that was the problem. I go to start it again and it still won't start!! I can hear my exhaust putt out sometimes and then it just doesn't want to start and then sounds like ****. The wires and distributor is set correctly and the timing SHOULD be set correctly as well. (TDC the Marks on the Cam-gear are even with the head.) I resanded all my grounds to make sure that wasn't a problem...anyone have any idea's? Fuses all checked out good, so did my main relay and my fuel pump works also. thanks!
Re: Help car won't start!! (CiViC_SOHC)
Your engine problem is a bit over my head, but the "recent topics" up by your name in the upper right corner will help you find your old thread
check for spark...pull a plug wire and hold it against something metal. have somebody crank it over and you should see it arc to whatever you're holding it against.
Re: (pdiggitydogg)
no..I havn't checked the compression but it is supposed to be 9:1 so...here is a video of it trying to start.. http://vids.myspace.com/index....99308
Unceasing Measure
Re: (CiViC_SOHC)
Explain to me exactly how you determined that the mechanical timing was correct before you tried to turn it over. If you're getting spark and fuel, compression or timing is the only thing holding you back.
Get back to use when you can post some new information.
4drint3gr4
11-29-2009 10:13 PM
mister.wong
09-13-2008 04:45 PM
westsideaznboi
27
04-24-2008 04:45 PM
importnoodles
09-28-2006 12:22 PM
killaj12
07-06-2005 02:18 PM
