couldnt break 80mph tonight.
so i took my OEM airbox, and installed a SRI arm, connecting to the airbox.
Things were good, untill my drive home i couldnt break 80mph. It just felt like at WOT i couldnt get above 80mph in 5th....its almost like i was going up a big hill, i was infact going downhill.
I did have the car running a total of an hour (took a long drive+idle), so i dont know if heat is the issue.
New plugs, cap/rotor, fuel filter wires, airfilter, fuel pressure is good.
i thought i fixed this, but the second i replaced the OEM arm with the aftermarket one, things went back to normal...shouldnt be like this..
could a leak after the TB cause this? maybe pressure loss?
Re: couldnt break 80mph tonight. (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">Downshift into a lower gear?</TD></TR></TABLE>
Re: couldnt break 80mph tonight. (egmatt93)
i had the same problem just the other day ..
it wouldnt go past 70 ... lol to high gear i down shifted to 4th and bam ... but that whats supposed happen give it a try ...
err wtf.
That's how u know u drive a Honda, can't do 80mph DOWNHILL.
Seriously though. That's some weird ****..you sure it didn't have to do with the turns in the road vs the gear you were in?
Ek Forever y0!
Re: (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">you must have that 8 valve 84hp motor from teh 92cx.</TD></TR></TABLE>
Word.
Word.
Re: (ek forever guy)
stealing your thread. sorry.
for you dohc guys out there. name your B H or K series and the top speed your car has maxed.
i have an em1 with the usual b16a2 and a supercharger. i got up to 120 but i was afraid to go more. anyone else?
Re: (SoCal EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal EJ1 »</TD></TR><TR><TD CLASS="quote">Considering I have yet to see a US speed limit >75mph, you really have no reason to go over 80. Stop complaining.</TD></TR></TABLE>
Texas has some 80 mph highways... don't ask me why I know this lol
btw my tired old D16 hits about 105, but it's mostly stock and soon to be swapped for a dohc, so yeah...
Re: (young noob)
thats odd i have a SOHC Vtec and I never need to drop down to 4th to pass of accelerate i just push the pedal further down and the needles just goes 70,80,90,110,120,121,122, bump fuel cut off.
its a d16y8 5speed, if i already didnt state that. Dont steel my thread n00bs.
Fukn with the OEM arm on there i could easily get past 80 like its nothing. And expletive that 75mph ****, i dont speed, and that has nothing to do with my problem. If i cant break 80, even with downshifting, thats an issue.
If i leave it in 5th, at 1/4th throttle then i can break 80mph....
could it be timing? or just a shitty SRI intake arm not sealing up to the OEM airbox?
Re: couldnt break 80mph tonight. (YoungKadafi)
Yea, you have soemthing krunk. I have a 95 LX (d15 sohc) and it'll do 105 in 5th (but give'er time to get there). I assume when you say SRI you mean short-ram-intake. Unfortunately, any air you pull from under the hood, can't be "rammed" into the intake...even moving down the road, anything behind the radiator isn't moving that fast...an SRI probably pulls the hottest air of OEM, CAI (the long ones that go down into a wheel well), and SRI...rule of thumb-and it is a general rule of thumb...every 10 degrees of air you pull heated (over STP @ 1 atm and 68°) costs you about 1 hp
Re: couldnt break 80mph tonight. (riverviewcivic)
dude we got my brothers old 1989 mercury grand-marquis to go like 105...now thats some scary ****
if you cant break 80 in 5th you have a problem. period. a geo metro would break 80 in 5th.
its a SRI arm attached to the OEM airbox and resonator, pulling ice cold air, plus it was -15 last night, not an issue..
and with the OEM airbox ARM attached, i could easily hit "6krpms in 5th"
were talking about a change, and discussing if its from the Aluminum arm, or just my car running for over an hour, having a very negative effect on performance.
it really did feel like my ebrake was on, so i dunno if the timing was somehow pulled? it really felt like my timing was REALLy retarded.
After that highway cruise trying to keep up with the other drivers, i took it on the back roads, below 4k rpms i had very little power. Almost like my ECU was getting disrupted by a short or something over time.
I have no CEL's, and this problem has been plaguing me for a long time. No exhaust leaks either
Re: (pli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pli »</TD></TR><TR><TD CLASS="quote">stealing your thread. sorry.
i have an em1 with the usual b16a2 and a supercharger. i got up to 120 but i was afraid to go more. anyone else?</TD></TR></TABLE>lolz stock b16 here and i had it up to 135... needle burried
Re: (pli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi »</TD></TR><TR><TD CLASS="quote">wait where did these ricer b's come from, no way did i ever mention i had a b series</TD></TR></TABLE>
From this dumbass
From this dumbass
Guest
Posts: n/a
check all the vacuum lines that run to the intake tract. Also theres 1 or 2 that go to the intake mani. you might have knoced something out or forgotten about it. a leak where u attached an arm from ur stock airbox wont do what u are mentioning, you can pull the sotck airbox off and leave just the accordian tube there and that wont even happen.....
