difference? jdm zc (sohc vtec) and d16z6?
as the title states, is there a difference between the jdm zc which is the sohc vtec version and the d16z6? between the block itself (not pistons and rods). what about the crank and head?
thanks
thanks
Re: difference? jdm zc (BryanLavo)
i was reading somewhere that the jdm SOHCs have stronger stock sleeves because they are comprised of different material and are layered differently. can anyone confirm this?
I did some research a while back on these engines, I'm almost positive that the bottom ends are the same. Its DOHC and I think it has like 40 more horses, For the price it didn't seem like a bad engine, but I opted to save for a LS swap.
Re: difference? jdm zc (stock_honda_coupe)
The D15B or ZC has....
Displacement : 1493 cm3
Bore and Stroke : 75 mm X 84.5 mm
Rod Length : 137 mm
Compression : 9.6:1
Power : 130 hp @ 6800 rpm & 102 ft·lbf @ 5200 rpm
Valvetrain : SOHC VTEC
Fuel Control : OBD-1 MPFI
3-stage VTEC
the d16z6 has....
Displacement : 1590 cm3
Bore and Stroke : 75 mm X 90 mm
Compression : 9.4:1
Power : 125 hp @ 6500 rpm & 106 ft·lbf @ 5200 rpm
VTEC Switchover 4800 rpm
Head Code : P08
Hope thats helps...
Rod Length : 137 mm
Compression : 9.6:1
3-stage VTEC
the d16z6 has....
Compression : 9.4:1
Head Code : P08
Hope thats helps...
Re: difference? jdm zc (sohc vtec) and d16z6? (BryanLavo)
I have this engine in my 95 LX Sedan and its identical to the USDM D16Z6, Stamp codes everywhere are the same except for the Engine code, which says ZC instead of D16Z6.
People forget but there are 3 ZC Engines, SOHC Non Vtec (D16A6) DOHC ZC (similar to D16A1) and SOHC ZC Vtec (D16Z6)
DOHC ZC Came obd0 and obd1 (rare, i have seen one in person)
SOHC Non Vtec ZC came OBD0
SOHC ZC Vtec came OBD1
what i know ZC & other D16 have the same block...difference is some carnkshafts & piston rods - minor...
the big differences are in head...the have the different shaped intake (the headshield gasket from D16 won't fit)...also they are different inside, when you open them & meassure them!
Re: difference? jdm zc (KLiK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KLiK »</TD></TR><TR><TD CLASS="quote">what i know ZC & other D16 have the same block...difference is some carnkshafts & piston rods - minor...
the big differences are in head...the have the different shaped intake (the headshield gasket from D16 won't fit)...also they are different inside, when you open them & meassure them!</TD></TR></TABLE>
i have this engine it is vtec sohc and its jdm
there is a dohc non-vtec zc but mine is not this
wow didnt realize so many people responded thanks anyone figures more out let me know thanks
phoQ
22
11-11-2021 07:59 PM
