(195 x 60 x 15) on OEM 15's si rims?
I'm about to purchase some nearyly new tires (195 x 60 x 15) for cheap. What i wanna know is that would they fit on oem civic si rims? I was told they are the same as 205/55/15. Will it rub, they're going onto a 00 ex coupe.
Re: (195 x 60 x 15) on OEM 15's si rims? (94_civicEx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_civicEx »</TD></TR><TR><TD CLASS="quote">name on the tires are called: warrior</TD></TR></TABLE>
"warrriors come out to playay....warriors"
how much they runnin you...
id say any tires at 75 $ w/little tread wear are good not great deal but good nonetheless, if you wear out your tires on quick like i do i highly reccomend you buy cheapest you can get btw- what kinda tires n=(not brand -but all season blah blah...etc
Darth ModerVader
Yes they will fit, but due to the larger overall diameter, your speedometer, odometer, and effective gearing will be affected by approximately 3%.
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
205/55-15 4.4in 11.9in 23.9in 75.0in 845 0.0%
195/60-15 4.6in 12.1in 24.2in 76.1in 833 1.4%
not too sure about the tire brand, but size shouldnt be a problem
HT White Ops
Stock size is 195/55/R15. 195/60's will rub when you hit bumps (they'll rub your fender liner), and may rub on the corners. I had 195/60/R15's on a set of blades on my hatch, and they rubbed like nobody's business.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Stock size is 195/55/R15. 195/60's will rub when you hit bumps (they'll rub your fender liner), and may rub on the corners. I had 195/60/R15's on a set of blades on my hatch, and they rubbed like nobody's business.</TD></TR></TABLE>
My buddy has 205/60 on his stock gsr blades and the only thing that happends is he looks like he is going off roading
Re: (cambopheonix56)
i tried 195 60 15 on my hatch.
im not lowered much at all. eibach sportlines. so 1.5" i think.
they rubbed bad. even the rears rubbed when the suspension squated around turns
stick to 195 55 15 please
I have 205/60 R15 on my 94 civic hatch with blades, dropped on eibach prokit springs. doesn't rub at all unless i make a really sharp turn or a fast turn going into a parking spot. Can't complain because the tires was free and i'm using them as winter tires.
EDIT: 195/60 not 205/60
Modified by shyboi4u at 3:43 PM 2/4/2007
Matty.
01-19-2005 10:30 AM
lOOkatme
04-11-2004 02:37 PM
