Problem with Brake Upgrade
I just bought a '93 Civic hatch which has Integra disc fronts and I think rears (or maybe Si rears). The problem is that the fronts are SUPER sensitive and stop with just a little pedal pressure but the rears hardly squeeze at all. If I pull the emergency brakes, with the car out of gear, I can still push the car. I've adjusted the cable and even replaced the rear pads without change.
I'm wondering if maybe the PO swapped the brake proportioning valve from the Integra also and this is why the fronts are so sensitive?
Any help troubleshooting this issue is appreciated.
Re: Problem with Brake Upgrade (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">The fronts do most of the braking. If you look at the rear pads, they are really dinky compared to the fronts. I could have my car rolling and yank the ebrake, and it still rolls.</TD></TR></TABLE>
exactly
Which prop.valve do you have (take a picture)
Which master cylinder/brake booster do you have
Are you sure it has teg calipers?
Have you properly adjusted the parking brake?
exactly
Re: Problem with Brake Upgrade (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">
exactly
Have you properly adjusted the parking brake?</TD></TR></TABLE>
I'll get pics of these parts asap
exactly
R_ACE1
12
08-16-2009 12:53 PM
sshaikh01
04-26-2004 04:33 PM
JDM TypeR 307
02-24-2004 08:30 AM
