Toe at -7.00º WTF!! help
ignore the other post, friend left signed on my computer...
just got an alignment since i raise my car up a little and got new rims/tires. well everythings fine except the right rear. it was at -6.7 to 7.00º! it was at max adjustment and couldnt adjust any lower. the rest of the car is fine. what could cause this to happen?
i never had a toe any where near this, and its just on one side. i never hit a curb or anything.
i dont have a print out since their printer was all jammed full of paper.
car is barley pulling to the left. it started doing this after i raised it up. so i still dont know how the hell this could happen.
HT White Ops
Re: Toe at -7.00º WTF!! help (platinumx6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinumx6 »</TD></TR><TR><TD CLASS="quote"> your problem is you took it to people who couldnt unjam a printer</TD></TR></TABLE>
PC Load Letter?
What the fvck does that mean?
PC Load Letter?
Re: Toe at -7.00º WTF!! help (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
PC Load Letter?
What the fvck does that mean?</TD></TR></TABLE>
huh?
PC Load Letter?
huh?
HT White Ops
huh?</TD></TR></TABLE>
How have you not seen Office Space?
To the OP:
Try taking it to another alignment shop. I'd see if you could get your money back for the first shop, no way in HELL that your toe should be 7 degrees out unless you bent something.
To the OP:
Re: (pdiggitydogg)
Try taking it to another alignment shop. I'd see if you could get your money back for the first shop, no way in HELL that your toe should be 7 degrees out unless you bent something. </TD></TR></TABLE>
it was like that before they touched anything. i've always gone to the same place.
and quit posting useless **** in here
HT White Ops
Re: (logiT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by logiT »</TD></TR><TR><TD CLASS="quote">
and quit posting useless **** in here </TD></TR></TABLE>
So you fucked up your car by sliding into a curb or slamming into speed bumps, and I'm posting useless ****?
GTFO.
GTFO.
Re: (logiT)
GTFO.</TD></TR></TABLE>
sliding into a curb, no.
slamming into speed bumps, no
talking about **** that doesnt relate to my question useless, yes.
HT White Ops
Re: (logiT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by logiT »</TD></TR><TR><TD CLASS="quote">old specs, LR -0.02º toe; -2.61º camber- RR -0.04º, -2.79º camber= Total Rear for Toe -0.02º Yes im am pretty low and no my old tires had little to no camber wear cuz my toe were pretty much 0 all around.</TD></TR></TABLE>
So what did you do? You had to have bent something, for your rear toe to be out 7 degrees. This is not something that will just "happen" ...
Re: (Eran)
So what did you do? You had to have bent something, for your rear toe to be out 7 degrees. This is not something that will just "happen" ...</TD></TR></TABLE>
thats the whole point of me asking...just looked and nothing seems bent or cracked.
HT White Ops
Re: (logiT)
thats the whole point of me asking...just looked and nothing seems bent or cracked.</TD></TR></TABLE>
Well, something had to have happened to your suspension that caused force. It doesn't just go 7 degrees out.
Re: (Eran)
Well, something had to have happened to your suspension that caused force. It doesn't just go 7 degrees out.</TD></TR></TABLE>
yeah..comparing it to the other side, nothing seems out of the ordinary. this sucks
Re: (logiT)
7 degrees is A LOT. it should be quite noticeable by eye if it's out by that much. take it to another shop and have them do a quick check.
Re: (SaYjAiBaO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SaYjAiBaO »</TD></TR><TR><TD CLASS="quote">7 degrees is A LOT. it should be quite noticeable by eye if it's out by that much. take it to another shop and have them do a quick check.</TD></TR></TABLE>
maybe their machine was reading wrong? ill take it to another one, i got lifetime alignment.
could a torn rear trailing arm bushing cause this?
how can you tell if the rear trailing arm bushing is messed up? it looks like the other side?
Modified by logiT at 2:59 PM 2/3/2007
Re: (platinumx6)
yeah..comparing it to the other side, nothing seems out of the ordinary. this sucks </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by logiT »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinumx6 »</TD></TR><TR><TD CLASS="quote">jack your car up and look for bent ****. come on now.</TD></TR></TABLE>
