H22 Vs B18b which one will i choose.....hmmm.
which one will literally crush the other? h22? or will the b18b? Or howbout a second opinion? b20z's up in this peice?
Re: H22 Vs B18b which one will i choose.....hmmm. (YoungKadafi)
Stock motor vs stock motor in the same chassis, the H22 will shred the b18b along with the b20.
for NA right? lets say we had the option of boost, later on down the road, could the H22 take a boosted *** whooping?
i think the h22 would be a good DD, what about the h22 up against a b16b?
Re: H22 Vs B18b which one will i choose.....hmmm. (sol2hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch »</TD></TR><TR><TD CLASS="quote">what? are you kidding? please tell me your drunk or something.</TD></TR></TABLE>
seriously im fittin to light this bitch up, in engine swap choices for daddy and his DD'ing crew
Re: (YoungKadafi)
I am not trying to be a dick or anything, but this has been beaten like a red headed stepchild in a third world country.
Search. You can boost anything, just as long as you stay within reasonable boundaries, and get a good tune.
I would go for the b20z, then build it later into a CRVTEC. but thats just me
Re: (YoungKadafi)
oh yeah im in this one!!!!
as far as boost goes on stock block people say its not good to boost h22's because of the sleeves made differently. but in my own opinion the pistons will give out before the sleeves do.
ill take a boosted h over a b series anyday. matter of fact h2b ftw!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi »</TD></TR><TR><TD CLASS="quote">seriously im fittin to light this bitch up, in engine swap choices for daddy and his DD'ing crew</TD></TR></TABLE>
I will take that as a yes.
Round 3....FIGHT!
All these options are good...H2B will have plenty of power and torque, plus nicer gearing with the B tranny...but CRVTEC doesnt sound bad either...all these with boost and a proper tune will get you all you need
Re: H22 Vs B18b which one will i choose.....hmmm. (soccerwuedo5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccerwuedo5 »</TD></TR><TR><TD CLASS="quote">Round 3....FIGHT!
All these options are good...H2B will have plenty of power and torque, plus nicer gearing with the B tranny...but CRVTEC doesnt sound bad either...all these with boost and a proper tune will get you all you need </TD></TR></TABLE>
CRVTEC isnt a bad setup, the only thing that kills them is the stock compression... then again the setup is great with just a set of high compression pistons (for NA of course).
Re: (YoungKadafi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi »</TD></TR><TR><TD CLASS="quote">how much tq does a h2b put out</TD></TR></TABLE>
My friend just got his bone stock h22 tuned.. if i remember correctly i'm pretty sure it put out like 179whp and 149 lbs.
say we put together a price, how much would a h2b vs a crvtec run? were going budget orientated here
does the b20vtec have the same oilin problems a ls/vtec has?
Re: (YoungKadafi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi »</TD></TR><TR><TD CLASS="quote">say we put together a price, how much would a h2b vs a crvtec run? were going budget orientated here
does the b20vtec have the same oilin problems a ls/vtec has?</TD></TR></TABLE>
Are we talking built crvtec or stock block with a vtec head on it?
If by oiling problem you are referring to the oil line that needs to be run to the vtec head, then yes you will need to do that.
Re: (sal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sal »</TD></TR><TR><TD CLASS="quote">
My friend just got his bone stock h22 tuned.. if i remember correctly i'm pretty sure it put out like 179whp and 149 lbs.</TD></TR></TABLE>
honestly, i dunno the real prices on these bamf's but i dont think their that expensive, why are people always so turned on by the b16a2s, i would assume the h22 would be in the same ballpark as the b16a's
Re: (YoungKadafi)
h22s can be had for cheap because they are not that popular of a swap, and are harder to put in than a b-series. Go to Hmotorsonline.com to look at some prices.
When I mentioned CRVTEC, I meant built. Stock wouldnt do much to impress me, but built with high comp pistons and the likes....
Re: (sol2hatch)
YoungKadafi, every setup you are looking into definitly have potential. If your looking to go for a stock setup the h22 would be your best bet but you cant just look at the cost for the motor... you will still need custom mounts and axles at the least, unless you go h2b right off the bat. If you go h2b depending on which kit you go with, you will most likely be able to use b series mounts and axles, or mounts supplied with the kit (referring to the evolution kit)
Re: (sal)
umm...gabreille(if i spelled that correctly) has an h2b putting 191whp to 149 i think
mines is dynoed but not stock so i cant say
Re: (YoungKadafi)
they dont have oiling problems if done correctly.
h2b will cost you more because of the adapter plate.
a duce duce stock bottom end with pistons and rod has been knowen to handle up to 30 lbs of boost. the jdm 94 h22's have a solid deck. (handles more boost)
Re: (sal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sal »</TD></TR><TR><TD CLASS="quote">YoungKadafi, every setup you are looking into definitly have potential. If your looking to go for a stock setup the h22 would be your best bet but you cant just look at the cost for the motor... you will still need custom mounts and axles at the least, unless you go h2b right off the bat. If you go h2b depending on which kit you go with, you will most likely be able to use b series mounts and axles, or mounts supplied with the kit (referring to the evolution kit)</TD></TR></TABLE>
Perfectly put H22 > all the set ups you have listed
But I Suggest H2B So Switching Back To B Series Is Only One Mount Away
Re: (50SaysHeEatsIt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 50SaysHeEatsIt »</TD></TR><TR><TD CLASS="quote">
But I Suggest H2B So Switching Back To B Series Is Only One Mount Away </TD></TR></TABLE>
a little more than a mount but ok.
