97 civic w/b16 axle help
Will stock d-series axles work with this engine if I remove the half shaft? Are the splines in the tranny the same?
Re: 97 civic w/b16 axle help (B16B_coupe)
What about mounts? I have a SI rear bracket but the engine didnt come with any mounts. Can I use the tranny mount and drivers side off the d-series?
HRD PKR
Re: 97 civic w/b16 axle help (b16a1eg6)
all 96-00 b/d series mounts are the same except for the two lower frame tq mounts.. and the rear trans bracket is diff between b/d series
