% Clutch adjustment 2000 Si?
The clutch pedal on this thing has to be let out almost all the way before it will grab. Supposedly the clutch is OEM with good life on it, it feels fine once it is going, no sign of slipping. My friend said it is hydraulic and cannot be adjusted for pedal travel? I hope he is full of sh*$ and I want to tell him so if I can find out here! Thanks!
HRD PKR
Re: % Clutch adjustment 2000 Si? (Mikes2000civicsi)
yes u can adjust the pedal play. by the pedal its self u can.. or u might have
a- a leak in the slave
b- a leak in the clutch master
c-worn out clutch
d-air in the system
c-worn out clutch
d-air in the system
Re: % Clutch adjustment 2000 Si? (4EN[sic])
Thanks for the smart *** comment mike. Yeah it.......like bothers me that much! It isn't right and I am not going to put up with it if I can adjust it, hence the reason I am asking, to get informatio so I can fix it if possible. Not to hate on someone or question their logic or the reasoning behind a perfecly viable and acceptable damn question! Maybe that is just great for you to have the clutch do its thing in the last inch of its upward travel but it is just not my thing. Have fun. Thanks, B16B_coupe
