Code 41 appears after Primary Oxygen Sensor Heater replacement
Hi There,
I have replaced the Primary Oxygen Sensor Heater on my 98 civic with a universal one, after I had code # 41.
Now, as I start, when the Engine is cold, the Check Engine Indicator lighs, then after I shut down the Engine and restart again the problem disappear. It happens only on the first start, when the engine is cold.
What might be the reason for that? Incompatible Sensor?
Please Advise.
Thank You
Please Advise.
Thank You
Re: Code 41 appears after Primary Oxygen Sensor Heater replacement (Ramireg)
have you tried not shutting it down when the CEL comes on? try resetting your ecu too, never hurts to do it.
Re: Code 41 appears after Primary Oxygen Sensor Heater replacement (DFW)
I have already tryed not to shut it down but the CEL is not disappearing. I have also tryed to reset the ecu, but it's the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ramireg »</TD></TR><TR><TD CLASS="quote">I have already tryed not to shut it down but the CEL is not disappearing. I have also tryed to reset the ecu, but it's the same.
go check to see if the cel is still throwing the same code then.
what brand of o2 sensor u get....u cant just get any type of 4wire o2 sensor i've found out many dont operate right. i know someone that sells them for $60 brand new w/ plugs if u need a new one. never had any problems w/ his customer service and products!
Re: Code 41 appears after Primary Oxygen Sensor Heater replacement (SpoonEk253)
Thanks,
I have replaced the sensor to a new Bosch type and averything looks ok now, it seems that the first one was not operating right.
Thank you once again.
