Nut on catalytic converter
The top nut, which is hard to reach, has rust on it so the 13mm socket won't fit over it. I've tried 14mm and it's too big. I've tried 1/2" and it's too small. I've tried 9/16" and it's too big. I tried a wire brush, tried WD-40...
Any ideas?
I've got an impact wrench... so once I can actually get a socket over it I'll have no problem...
Any ideas?
Re: Nut on catalytic converter (thw_goalie)
have you tried taking the cat off from the header, so the exhast hangs lower? its a bit easier to get to that way.
use a extractor socket. It has spriral cuts inside and if needed hammer it on the nut(obviously your going to have to replace the nut) and turn it with a rachet.
Re: (stock_honda_coupe)
if you really can't get it off:
https://honda-tech.com/zerothread?id=1871975
Juans_MX3
42
07-10-2021 04:38 PM
OmgDelSol
04-15-2014 08:29 AM
JDM_CRX_PLEASE
12-22-2007 09:24 PM
