For those all motor d-series junkies check it out!!
Well i was checking around summit after ordering an edelbrock header for dirt cheap and I saw they had the arias pistons for a D16a6 on clearance for $291.50 so i did some researching and and calculation. So I wanted to know if my calculations were correcte that those pistons will yield a 11.9:1 CR on a D16y8 with a y8 2 layer headgasket.
The summit part number is ARA-3330000-NR
and the specs for those pistons from the Arias Website are:
Dome Top
Bore: 75.05
Compression Height: 1.166
Dome cc: -0.3
Estimated CR on a stock D16a6 Head: 10.5:1
Gram Weight: 242
I believe that is a really nice compression for the street for those that don't want to run a sky high 12.0:1 to 12.8:1 CR that you get from the p29 or pm7 pistons plus the arias are forged and are perfect nitrous or supercharged if i'm correct!
Dome Top
Bore: 75.05
Dome cc: -0.3
Gram Weight: 242
jdm_sir2
02-17-2007 01:54 PM
