Motor Swapped ... Cant go anywhere tho lol ..
Alrite i did a motor swap d16z6 with d16y8 trans...
All the gears go in and out i even hear reverse ... but it does this with or without the clutch up or down ... but if i press the clutch all the way down i hear a lil whinning noise ... Does anyone know what i did wrong?? Car does not move anywheres even if i release the clutch in any gear it doesnt stall or anything it feels like its still in neutral....
no, but i think its either of those .. i have trans fluid comin out teh axle .. wow this sucks have to take the trans out and see what went wrong ... im thinkin its the clutch or tob is shot
If you have trans fluid coming out of your axle then your problem is your axel isn't seated properly in the tranny. You need to push it in further, then it should move the car. No need to remove the entire tranny.
Re: (thegoudster)
yep, sounds like an axle for sure. you gotta tap those guys in place and make sure they are seated properly. if you cant get in there with all of your suspension back together just pop off the axle nut and use a soft face hammer and tap it in. you could just flip the nut over to give you enough to press the axle all the way in. waaay easier then pulling the trans.
Well, fix the axle issue first. What I do is used piece of MDF against the cup and boot and pound lightly until it's in a reasonable distance. I've heard torn or damaged a boot/cup doing this cuz it MDF board...
Re: (92VXeg)
loll i still didnt touch it yet ... i might need a new clutch tho.. i found a brand new sach clutch with tob for $100 .. guess i cant go wrong...
day1
Transmission & Drivetrain
03-03-2010 06:29 PM
jxhxb
10-08-2009 09:55 PM
