d16y8 intake manifold
Seagull Management
Re: d16y8 intake manifold (Dub9.Juice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dub9.Juice »</TD></TR><TR><TD CLASS="quote">how do i find see the differences between the auto and manual ex manifolds? somebody help kay thanks =]</TD></TR></TABLE>
The manual EX manifold uses a 2 wire IACV mounted to the back of the intake manifold like most other B abd D series engines. The automatic Y8 manifold has the IACV mounting blocked off and instead uses a 3 wire IACV mounted to the throttle body, the same as all Y7s.
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dub9.Juice »</TD></TR><TR><TD CLASS="quote">and i should put on a auto ex manifold with a 3 wire ivac right?</TD></TR></TABLE>
Right
Right
Re: d16y8 intake manifold (94EG8)
so thats automatic right making sure ima bit slow lol sorry because in some other threads ive read through out the internet it says that automatic intake manifolds do not have the drilled holes in the back and would it really matter if i have a obd2 vtec harness and just leave the vtec silonoid plug just..hanging?
Seagull Management
You've somewhat lost me, but yes thats an automatic Y8 manifold. Automatic Y8 manifolds don't have the holes drilled in the back, this is why you want the automatic Y8 manifold when swapping the manifold only onto a Y7. Don't use a vtec harness, unless its for an automatic because you will have to repin wires to get the IACV to work and you will need to add one wire as well.
perseverance
11-03-2006 08:39 AM
dw.VTEC
04-08-2005 03:59 PM
tallblondkid
12
02-07-2005 10:59 PM
