please help..tach. problem
Old 08-09-2008, 10:19 PM
mojackson2390's Avatar
Default please help..tach. problem
ok no one yell at me for this, its probably pretty stupid but i am knew to this whole honda thing. so i just bought a 96 civic that has a b16 swap but the speedo and tachometer don't work..is it a fuse or wiring problem or what? i was also wondering if anyone in San Bern. or I.E. might know where i can take this car if i want all of the crappy wiring job fixed and cleaned up.any help is appreciated thanks
Old 08-10-2008, 05:21 AM
mongtite's Avatar
Default Re: please help..tach. problem (mojackson2390)
possibly the VSS or Vehicle Speed Sensor not working if the Speed Gauge and Mile indicator doesn't work.
Old 08-10-2008, 09:10 AM
vtecb18c's Avatar
Default Re: please help..tach. problem (mongtite)
well considering your saying that its a hack job, its probably the wiring...im not from cali but im sure someone will chime in with a reputable shop in your area that you can take it to..... that sucks to get a b16 swapped civic and have no vtec
Old 08-11-2008, 10:36 AM
Default Re: please help..tach. problem (vtecb18c)
i really dont get vtec if its throwing an engine light or any code?
Old 08-11-2008, 10:58 AM
devney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mojackson2390 &raquo;</TD></TR><TR><TD CLASS="quote">i really dont get vtec if its throwing an engine light or any code?</TD></TR></TABLE>
It depends on the code that is thrown. Your check engine light can be on and VTEC will still work. Just depends on the issue.
EDIT: Is VTEC working or not? I didn't see you say anything about it, I just assumed because someone mentioned something about it.
Old 08-11-2008, 11:00 AM
Eaglekper0046's Avatar
Default Re: please help..tach. problem (devney)
The VSS code is being thrown, so vtec won't work if its thrown
Old 08-12-2008, 10:19 PM
Default Re: please help..tach. problem (Eaglekper0046)
what is the VSS code? and i tried to pull my codes, but i suck a wire in the plug and turned the key and nothing happend the engine light just stayed on.
jaydm ferio
11
12-13-2004 07:19 PM
jaydm ferio
12-06-2004 08:54 PM
Freshazzburu
10-17-2004 10:12 PM
dash8264
13
02-09-2004 02:02 PM
DV98CVC
04-30-2003 08:49 PM
Quick Reply: please help..tach. problem
