Is My car Vtech
Is My car Vtec
I just bought my first honda (a 95 civic ex). The valve cover says VTECH HONDA, but there is not "boost" at 6k rpm that typical vtech engines have. My car does not have the original engine in it because the previous owner blew a piston. Is my car actually a vtech engine and it just doesnt kick in until like 7k or 8k rpm or is there a sensor or something unplugged or somebody just grabbed a random valve cover and threw it on b/f the previous owner purchased this engine.
Thanks
Modified by 95exvtech at 6:26 PM 8/10/2008
Thanks
Re: Is My car Vtech (95exvtech)
there is a place on the block where the motor code is imprinted.i think its rite under the headers.if the engine has vtec then then its probably not wired rite.i dont kno how to wire vtec but i hope this helps.
if your valve cover says "vtech" than theres somethin wrong lol..is it painted on? or does it say "VTEC"? now if it does and which the EXs do than yes its vtec(also considering you cant but a vtec valve cover on a non vtec engine )....there really isnt much of a vtec kick with stock single cams and most of the time you cant hear it(without an intake and some i still cant hear it) ....you can check to see if the solenoid is good or clean the pressure switch maybe its not engaging its possible that when they did the swap they didnt hook all the wires up so i would go get a haynes manual and go over the whole vtec system(there is a lot of reasons why vtec could not be engaging oil pressure, bad soilniod, faulty wiring, dirty soiloid gasket screen, VPS ect....) you need to trouble shoot if you think its not working
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95exvtech »</TD></TR><TR><TD CLASS="quote">I just bought my first honda (a 95 civic ex). The valve cover says VTECH HONDA</TD></TR></TABLE>
No honda valve cover says vtech, some do say vtec though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95exvtech »</TD></TR><TR><TD CLASS="quote">but there is not "boost" at 6k rpm that typical vtech engines have.</TD></TR></TABLE>
Its not a turbo, you wont normally feel vtec unless you've got a type R or B16, you will just hear it engage, that said your engine is a D16Z6, SOHC vtec, and the vtec engagement is quite quiet.
Re: Is My car Vtech (vtecb18c)
Nah its not painted it is a legit valve cover. I was in my buddys 95 integra that havs vtec and if you watch the tach you see the jump in rpms when vtec kicks in. I was also in my other buddies 99si and he has that same noticible jump. I was just looking for that "jump" on my car.
Your motor is a tiny SOHC (Single Over Head Cam). You will never feel it "Kick" like you would in the larger DOHC (Dual Over Head Cam) motors.
Your friend has either an LS VTEC Swap in his Integra, or a GSR motor. and the Si is a B16.
Both of these are larger DOHC motors where there is a noticable feel and sound to VTEC engagement.
Doesn't really matter, they're all slow.
well you were in a gsr and a b16 powered si...both b series engines...they have loud vtec crossover and you can feel it...you have a d series which you will not get anywhere near what your buddies have with vtec engagement
Re: (enigma's95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enigma’s95 »</TD></TR><TR><TD CLASS="quote">i also have a z6...vtec hits at 4400 not 6k for me....sound about right to anyone else? *shrugs*</TD></TR></TABLE>
thats where mine use to engage...when i had a VTEC motor and ummm OP why would ur SOHC rev to 8k? oh and uhh the VTEC soleniod is on the back left side of the head incase u were wondering where it was
Re: Is My car Vtec (95exvtech)
Most likely your car does have vtec, but like everyone else said it's a single cam it's not going to sound or feel like a B series unless it's built.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95exvtech »</TD></TR><TR><TD CLASS="quote">I just bought my first honda (a 95 civic ex). The valve cover says VTECH HONDA, but there is not "boost" at 6k rpm that typical vtech engines have. My car does not have the original engine in it because the previous owner blew a piston. Is my car actually a vtech engine and it just doesnt kick in until like 7k or 8k rpm or is there a sensor or something unplugged or somebody just grabbed a random valve cover and threw it on b/f the previous owner purchased this engine.
Thanks
Modified by 95exvtech at 6:26 PM 8/10/2008</TD></TR></TABLE>
this is all a big joke. youve all been had. no way this is real.
Thanks
