doing rear disc brake conversion on 92 civic HB - use integra ebrake line?
Hi there, im doing my suspension and was working on the rear trailing arms on my 92 hb. i read the stickies and it says to use 94-01 integra ebrakes.
when i compared the 2 trailing arms, stock vs the integras, i noticed that the ebrake, on the driver side at least, is about 1.5 - 2 inches longer. Is this normal or am i supposed to get ebrakes for another car when swapping in HB, thanks!
thanks man. i shoudl have used your lca i bought off you, the bushings were in good condition. i spent 125 for new integra lcas well, at least i can put a sway bar later.
so how does the extra slack on the teg ebrake go? i guess i just tighten up the ebrake holder in the car more so its tigher. thanks again. i had another question, but i cant friggin remember it now.
on the side note, i swapped out the rear trailing arms and was putting in new rotor and pads in the back, man, it's more work than the front!
Re: (BlueIntegraBoy)
i did the conversion on my old coupe and i used all 94-01 teg parts. except the e-brake lines wernt working (wouldnt lock up) turns out one broke (and sezied my caliper , and i found a set off a ex abs and took that rear cable. worked like a charm. As long as you mount up the cables in the stock location it should work.
BOOSTED RIVAL
12-06-2006 08:00 AM
MugenHonda
06-12-2003 05:14 PM
