97 civic with 00' b16a2 why doesnt the fan work and the gauges ?
im thinkin i have to buy the del sol wiring harness and ecu what do u guys think, i didnt do the swap some kid did it to his gurls car and she came to me to fix it, they cut the harness under the dash and ran the 2.5 harness to the ecu just like the 00' civic si but some **** doesnt work so what u think would be the cheapest way out to fix this
? thanks guys
? thanks guys
Re: 97 civic with 00' b16a2 why doesnt the fan work and the gauges ? (racerboyb18c1)
i would check all the wiring again and simply tracing to what you have.
Re: 97 civic with 00' b16a2 why doesnt the fan work and the gauges ? (eg6ajk)
sounds like someone did a shitty wiring job.
*the cheapest way to fix it??? hmmm...IMHO it would be worth it to source your harness, imagine tracing all those wires...... . any obd2 civic VTEC harness should do. then figure out if you want an obd2 or obd1 ecu. you'll need a conversion harness to run the obd1 ecu though....hope that helps.
savestheday13x2
16
02-01-2005 06:36 AM
