Tranny leak?
Old 08-02-2003, 05:46 PM
White HB's Avatar
Default Tranny leak?
When i jacked up my car today i noticed that there was some leak on where the tranny and block touch together, it was on the bottom of the tranny.
What could be wrong? i just had 2 new axle seals up in its not from the axles
Old 08-02-2003, 05:58 PM
nsxmatt's Avatar
Default Re: Tranny leak? (White HB)
Are you sure it's tranny fluid? Rear main seal will cause that leak, also there is a seal on the backside of the input shaft bearing in the tranny that can leak.
Old 08-02-2003, 06:07 PM
White HB's Avatar
Default Re: Tranny leak? (nsxmatt)
What would the leak be?
Can you explain what the rear mail seal is? and input shaft bearing?
Old 08-02-2003, 06:10 PM
nsxmatt's Avatar
Rear main seal is on the backside of the flywheel. It's the passenger side crank seal is what it amounts to. The input shaft seal is inside the tranny and must be pulled apart to replace.
Old 08-02-2003, 06:13 PM
White HB's Avatar
ah ****. looks like this is gonna cost me alot of money
Old 08-02-2003, 06:30 PM
nsxmatt's Avatar
Is it dripping on the floor or is it just moist? If it's dripping then I would get it fixed, if it's just moist it could go on for a while. Just gotta find out where it's coming from first.
Old 08-02-2003, 06:42 PM
White HB's Avatar
ya it was just moist. i just whiped it down and gonna check tomorrow if it has come back.
Egpower88
07-21-2009 08:28 AM
eh3 93
07-24-2006 08:04 AM
krazycivic4u
06-25-2006 11:11 AM
Quick Reply: Tranny leak?
