Si Guages (92-95) Need help, having shorts...
Old 07-31-2003, 10:59 PM
oneoldcrx's Avatar
Default Si Guages (92-95) Need help, having shorts...
NEW QUESTION BELOW!
Yeah i got a ticket cause i was going too fast. Didnt know it cause my speedo was not working at the time (i just bought the car, didnt know it happened). I need to know how to fix them. Like how to get under the dash what to look for once i get behind it and stuff. I dont know, im such a noob at that stuff. Thanks for any help.
EDIT--NEW QUESTION-
I got the guages out and stuff found the clip that plugs into the cluster. Its just one large clip, which color is to the speedo? Thanks
For the info- wire color as below
Blue w/ white stripe
Solid green <-------My guess (but I don't know anything so...)
Solid yellow
Yellow w/ green stripe
Solid Black
Green w/ yellow stripe
Blue w/ red stripe
Green w/ red stripe
Red w/ green stripe
Modified by oneoldcrx at 2:59 PM 8/1/2003
Modified by oneoldcrx at 3:13 PM 8/1/2003
Old 07-31-2003, 11:38 PM
egcivic94's Avatar
if your spedometer does not work then you need to take out the cluster and look at the wire harnness on the back and see if it is hooked up. if it is and you still got that problem then you need a new cluster
Old 07-31-2003, 11:59 PM
vtec_racer_2kgsr's Avatar
Default Re: (egcivic94)
is this si blue?
Old 08-01-2003, 04:33 AM
neilff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivic94 &raquo;</TD></TR><TR><TD CLASS="quote">if your spedometer does not work then you need to take out the cluster and look at the wire harnness on the back and see if it is hooked up. if it is and you still got that problem then you need a new cluster</TD></TR></TABLE>
what?? this is wrong
its most likely the VSS, did you drive thru water recently?
go into your engine bay, and located on top of the transaxle is the VSS sensor, unplug it, take it out, take a hair dryer, and just blow the sensor and the harness plug..
its hard to explain where it is, just look at the tranny from the right side of the car, you'll see it then.
Old 08-01-2003, 05:06 AM
oneoldcrx's Avatar
I really just need to know how to get to the gauges, as if I were changing guages...even if thats not the problem. I have to get back there to mess w/ some other stuff too.
Modified by oneoldcrx at 2:38 PM 8/1/2003
Old 08-01-2003, 06:05 AM
oneoldcrx's Avatar
There arent any wire guru's out there? Sorry to be impatient but I HAVE to have everything put back in by noon today.
Old 08-02-2003, 07:57 AM
neilff's Avatar
Default Re: (oneoldcrx)
k, take out the 4 way button
then unplug that connection
then pop out the gauge cover thing (has all your vents in it)
the cluster comes out with 3 screws behind all that
very very basic
rediye
Honda Civic (2001 - 2005)
17
10-06-2023 03:10 PM
bakoCRX
07-16-2009 07:25 AM
itr1235
03-16-2006 01:52 PM
Turbo Powa
22
06-29-2003 11:45 AM
Fuster_Cluck
04-22-2003 08:56 PM
Quick Reply: Si Guages (92-95) Need help, having shorts...
