94 integra cat back system fit 93 hatch?
i need an exhaust system and found a DC catback system for the 94 integra for cheap. wil it fit or can i at least modify it to fit at least?
Re: 94 integra cat back system fit 93 hatch? (nextelbuddy)
any one know? sorry to bump so early but thers a guy selling it on another forum locally and i want to know if i shoudl get it before he sells it to someone else
you can use the header+cat+b pipe from an ITR on a 92-95 hatch..
However the muffler wont fit as it's quite a bit longer ...
Re: 94 integra cat back system fit 93 hatch? (ce)
ah so basically the axle baqck part wont work cause its too long but the CAT and B pipe which is between the CAT and axle back will fit.?
im sure you could mod it to fit....if u wanna wait a couple hours i have a integra at my house and a friend is coming o ic na put tmy stock exaust on his car and take it ghetto crush bent broke *** muffler wexhaust cause its too loud, i can see houw much of a diff there is between my civic exhaust and the integra and see if i think it coul dbe modded to fit, i have a 95 coupe not a hatch but it should be too much idff....
official honda whore
actually the coupe and the hatch's exhaust are quite different
the teg b pipe and cat will bolt up to the stock exhuast manifold and then to the stock axle-back, but in order for the axle back to fit a couple of modifications are needed but any shop should be able to do it
Re: (coptzer)
what about the hanger locations on teh teg b pipe? will they be in the correct location so i can hang them on the rubber things to hold the b pipe up?
Re: (nextelbuddy)
so i could go ahead and buy the integra cat back and just take it up to the muffler shop and they should be able to make it fit no problem? or shoud i just buy a muffler and go to the muffler shop and tel them to make custom 2.25 in piping all the way to the back? another thing, dos the teg cat back fit the hatchbakc better or the coupe better?
googoodc
01-22-2009 04:43 PM
Nickboxer7
04-11-2008 03:23 PM
