LS in Civic HB
LS in Civic HB
Im putting an OBD 1 LS motor and Trans into a 93 hatch. is everything gonna fit right in without any wireing or anything? i've searched but still confused. what type of gearing should i expect out of the LS trans (mph wise) any help would be greatly appreciated. will i notice a serious gain in power with this swap. i have a 1.5 liter SOHC non vtec motor now. thanks
Re: LS in Civic HB (Jaskula1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaskula1 »</TD></TR><TR><TD CLASS="quote">Im putting an OBD 1 LS motor and Trans into a 93 hatch. is everything gonna fit right in without any wireing or anything? i've searched but still confused. what type of gearing should i expect out of the LS trans (mph wise) any help would be greatly appreciated. will i notice a serious gain in power with this swap. i have a 1.5 liter SOHC non vtec motor now. thanks</TD></TR></TABLE>
well i know all your questions can be answered by searching. there are pleanty of threads about b series swaps into eg chassies sense this motor doesn't have vtec, then it will be a derect drop in and bolt up as long as you have everything you need from the integra motor, im not trying to be a dick but all your answers are on here, and if youre swaping this motor in and don't know what kinda of numbers it has well i feel bad for you
if you get the ls harness, it will plug right in.
Things you need:
ls throttle cable
integra shift stabilizer and linkage rod
integra upper mounts (3) and civic lower torque mounts (2) (you can use integra, but you have to grind off these tabs on the frame rails)
ls ecu
the integra header flange looks like this "/" and the civic looks like "\" so your exhaust wont bolt on, have to have the flange cut off and rewelded
Things you need:
ls throttle cable
ls ecu
in my 92 integra im getting 25-30 in 1st, 55-60 in 2nd, 80-83rd, and 120 in 4th thats with a ebay intake and some ghetto exhaust that was on there when i bought the car
