crazy trans whine?
crazy trans whine?
Bought a 97 ex like a month ago and now the trans is making a crazy whining sound while driving nad idling w/o the clutch in. Im almost possotive its the throughout bearing. comments please.
P.S. Would a DX tranny be better on my y8. dx trans=FREE
Re: crazy trans whine? (boo bees)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees »</TD></TR><TR><TD CLASS="quote">Bought a 97 ex like a month ago and now the trans is making a crazy whining sound while driving nad idling w/o the clutch in. Im almost possotive its the throughout bearing. comments please.
P.S. Would a DX tranny be better on my y8. dx trans=FREE</TD></TR></TABLE>
the dx tranny would not be better for your Ex but but if its free might as use get it and use it and rebuild your ex tranny
Risky Business
I AM positive it is the input shaft bearing.
Symptoms: https://honda-tech.com/zerothread?id=590820
Replacement: https://honda-tech.com/zerothread?id=596873
A pic:
What happens if you don't fix it soon:
The ISB will get chewed up and thrown all over the tranny...destroying it and locking it up. Tom (B18C5-EH2) said he drove around for a few months on a bad one and he was locked out of gears (destroyed tranny).
A pic:
Re: crazy trans whine? (BauleyCivic)
Yeah Im in the process of fixing mine. It's really not hard if you can get a decent bearing (ORDER OEM TO BEGIN WITH AND SAVE YOURSELF THE TROUBLE!!!)
Solbros Owns Me
Re: crazy trans whine? (Ricey McRicerton)
yeah, if it's doing it moving and idling with the clutch engaged, that means it's a bearing on the maain shaft...and that would be either input shaft bearing or the main shaft case bearing...
but the ISB is most common to go out
Re: crazy trans whine? (Ejay Six)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ejay Six »</TD></TR><TR><TD CLASS="quote">Someone broke into your house and installed a supercharger in your car.</TD></TR></TABLE>
lol
But yea it is the ISB
lol
Re: crazy trans whine? (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">yeah, if it's doing it moving and idling with the clutch engaged, that means it's a bearing on the maain shaft...and that would be either input shaft bearing or the main shaft case bearing...
but the ISB is most common to go out </TD></TR></TABLE>
Dammit Evan, the ISB and the main shaft case bearing are the same thing!
The ISB is actually in the housing. Check this out y0!
Part no. 4!
Part no. 4!
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Part no. 4!</TD></TR></TABLE>
no, I'm talking about the bearing at the end of the main shaft....I dunno what it's called...figured the main shaft case bearing would suffice.
Pull a tranny apart, you'll see
Risky Business
Pull a tranny apart, you'll see </TD></TR></TABLE>
In the EX tranny the bearing is pressed into the case, with the DX tranny it stays situated at the top of the mainshaft...but I know which bearing you are talking about
Mine's in peices.
I do know what you're talking about though.
My bad y0!
EDIT: ****...take your pick. You're talking about the bearing on the end of the mainshaft on the left of the picture correct?
Modified by Ricey McRicerton at 10:43 PM 3/30/2004
Mine's in peices.
My bad y0!
Risky Business
Re: crazy trans whine? (dragncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragncivic »</TD></TR><TR><TD CLASS="quote">throughout bearing </TD></TR></TABLE>
End yourself
End yourself
Wrong.
Wrong.
Risky Business
open it up, spin all of the bearings, the ones that click you replace them y0
The two i've opened up only the ISB was bad...the rest were good
Location: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
trans bearings. same problem. sometimes its cheaper to just replace the trans.
Risky Business
Re: crazy trans whine? (NJHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJHatch »</TD></TR><TR><TD CLASS="quote">trans bearings. same problem. sometimes its cheaper to just replace the trans.</TD></TR></TABLE>
$20 bearing < $250 used transmission that possibly has the same problem
Solbros Owns Me
if the bearing vibrates a little when you spin it, but visibly looks good...
for the most part, clean it in a parts washer and spray it clean, then lube it up and it will be fine. No need to replace if it vibrates/makes noises unless it still does after cleaned and lubed
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees »</TD></TR><TR><TD CLASS="quote">I mean i Have no prob replacing the bearing but I can get a DX tranny for free</TD></TR></TABLE>
With a DX tranny your car will feel like a DX.
