Help w/converting a 2000 ex coupe to auto from manual......
Re: Help w/converting a 2000 ex coupe to auto from manual...... (civicaleg)
so you are wanting to convert your manual transmision car to a automatic?
Rob
Rob
Guest
Posts: n/a
Re: Help w/converting a 2000 ex coupe to auto from manual...... (ekb18cCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18cCivic »</TD></TR><TR><TD CLASS="quote">wow.. sucks.. make her learn.. or truthfully sell the car and get her an auto</TD></TR></TABLE>
Agreed this is going to be alot of work. . . Just trade someone on here for an Auto i'm sure they wont mind or just sell your car and buy an auto if you look hard enough you could make money of that deal
Re: Help w/converting a 2000 ex coupe to auto from manual...... (SkRiBLaH)
I am not sure if it is the same since you are using a 6th gen, but in my 5th gen I used the same harness to go to a manual when my car was an auto.
It could very easily take the same harness. The ECU can be converted to work with auto I would assume. I had mine converted to manual, while it was also being chipped for use with peak/hold 450cc injectors.
I am not 100% sure but I would say about 85%
Re: Help w/converting a 2000 ex coupe to auto from manual...... (fookle)
thanks, for the info, i have a whole auto car, just need to know if the ecu and harness will interchange. 98 4dr auto non vtec, 00 coupe manual.
since you got a whole AUTO car like you said, then that solves the whole problem..let the wifey drive that one...BOOM! problems solved..
Re: Help w/converting a 2000 ex coupe to auto from manual...... (Got Utensils)
that would be easy right. why didn't i think of that. the 4dr is a total. please, anyone with technical info please reply. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicaleg »</TD></TR><TR><TD CLASS="quote">thanks, for the info, i have a whole auto car, just need to know if the ecu and harness will interchange. 98 4dr auto non vtec, 00 coupe manual. </TD></TR></TABLE>
Nope i dont think that it will work,
98=obd2a
00=obd2b
I dont think that the 2 harness will match. not to mention if you are in california, you will not pass inspection because you will have the wrong ecu in the car, abd2a ecu in an obd2b car.
Rob
98=obd2a
00=obd2b
Rob
JhonJhon619
03-01-2009 06:17 AM
Addicted2Racing
Honda Civic (2006 - 2015)
03-20-2007 03:18 PM
norcalboy_abe
12
02-14-2007 08:55 PM
rota power
18
12-18-2005 10:05 PM
