Highest OEM piston for my d16z6?
Highest Compression OEM piston for my d16z6?
I've got a bunch of spare sohc motors and i wanted to play around with my spare z6 motor. Whats the highest compression OEM piston I can put on my d16z6?
Modified by boredracer408 at 11:21 PM 3/29/2004
Re: (ShadyEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 »</TD></TR><TR><TD CLASS="quote">nah, throw 88-89 D16A1 integra pistons in there. they are the highest dome oem usdm d-series pistons
and very cheap</TD></TR></TABLE> really? i never knew that! BUMP for you!
Re: (ShadyEH2)
And even better - is the JDM dohc ZC pistons (PM7). They will give almost 12:1 compression on a z6 motor.
I have a set for sale, 75mm std bore in good condition if you want - includes rods. PM me.
liam
liam
Re: (ShadyEH2)
using those along with a D16y8 2 layer headgasket will give you close to 14.1:1cr
now that would be bad ***
Re: (pr0ject Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr0ject Eg6 »</TD></TR><TR><TD CLASS="quote">
now that would be bad *** </TD></TR></TABLE>
hate to break it to ya - but the y8 head gasket is a 3 layer gasket. And its the same thickness as the z6.
Also ZC pistons in a z8 will give you about 12.x compression. Not 14:1.
y7/y8 headgasket p2j
liam
liam
Re: (AzCivic1.6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzCivic1.6 »</TD></TR><TR><TD CLASS="quote">civic gx pistons.</TD></TR></TABLE>
The problem with GX pistons is the valve relief...none on the exhaust and hardly any on the intake side.
here is a GX piston
98-00 GX
D16..
total height: 49.28mm
compression height: 30.50mm
2.50mm dome
liam
here is a GX piston
98-00 GX
D16..
2.50mm dome
liam
hmm, interesting stuff.
I was going to make a separate thread about this but I figured I might as well ask in here because its kinda on topic.
What is the difference between using a taller piston, and a shorter headgasket?
if you were chosing one or the other,
and each would yeild the same CR
why would one be better than the other??
thanks.
thanks.
Re: (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 »</TD></TR><TR><TD CLASS="quote">
here is a GX piston
how do they get it to work in the GX engine? different head setup?
here is a GX piston
Re: (AzCivic1.6)
how do they get it to work in the GX engine? different head setup?</TD></TR></TABLE>
Thats my guess - just a different head design. It would have to be. I dont know what the GX head looks like so i really couldnt tell ya.
liam
liam
Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">hmm, interesting stuff.
thanks.</TD></TR></TABLE>
When you say "taller piston" im thinking you mean has a larger dome. You cant use a "taller" skirt (ie piston goes beyond the height of the deck) because it will impact with the head.
A larger dome will increase the compression however - and so will decreasing the head gasket height. However - a head gasket is 0.037 inch high (0.93mm) so you cant really get much of a change. You can mill a few mm off the bottom of the head causing the compression ratio to increase also.
When milling the head or using thicker/thinner head gaskets you have to worry about your timing. For each .012" (0.30mm) = 1 degree of timing change. So if you use a 2mm head gasket your changing the timing a fair amount.
Now the difference between in performance - i sorta have an idea but is hard to explain. Anybody?
liam
liam
Re: (sk8rmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8rmike »</TD></TR><TR><TD CLASS="quote">i've held both the y8 and z6 headgasket in my hands at the same time...and while they are both 3 layers...i noticed the y8 seemed noticeably thinner...</TD></TR></TABLE>
Ive measused the gaskets - and they are both the same.
liam
liam
Re: (sohcMONSTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcMONSTER »</TD></TR><TR><TD CLASS="quote">will these pistons also work in a d16y8? what would the comp ratio be on the y8, the same as a z6?</TD></TR></TABLE>
Yea the pistons work in a y8; the y8 has a smaller combustion chamber - 32.8cc vs the z6's 34.6. That increase gives you ~0.2 increase in your compression ratio. Its going to be a little over 12:1.
liam
liam
Re: (SloCivicHMM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCivicHMM »</TD></TR><TR><TD CLASS="quote">you guys are talking about the JDM ZC pistons right?
What stock pistons can I throw in my DOHC ZC to up the compression??</TD></TR></TABLE>
Honda doesnt make any. If you want to increase the compression in your dohc ZC you are going to either have to mill the head or use aftermarket pistons.
liam
liam
jetpilot
11-09-2006 05:49 AM
