Climate control clip
Does anybody know what climate control clip this is? And how exactly i would go about getting it off so that i can pull out my climate control? This heater controller is the only thing holding it on, (the silver thing in the picture) And i can't seem to get it off - any tips!?!?!??!
Re: Climate control clip (0ptimus Prime)
u get to it from under the glove box i think i didnt know at first and started to tug on that cable and broke the tab that holds it in place now its all messed up look like im goin to need some jbweld
at the jetties fishin'
pull down somewhat on the cable if you can...if you have to...bend the ****** and then wiggle it out then bend it back.
they hold in place because of a tight "S" bend. you might have to take that wire loose at the other end if bending it doesnt settle with you quite right.
Re: Climate control clip (stackz)
i see, also, there's a bastard green harness clip connected directly behind the climate control - it's almost IMPOSSIBLE to reach - how am i supposed to get that out?
