White Smoke :/
White Smoke :/
Replaced the headgasket on my D16y8 and im still blowing white smoke. I bought some engine flush and refilled with fresh oil, still blowing white smoke! Is it possible there is still some coolant in the oil pan? Might need to drop it and clean it out good? Any suggestions?
Tia!
Tia!
Re: White Smoke :/ (civic97b18csi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic97b18csi »</TD></TR><TR><TD CLASS="quote">Replaced the headgasket on my D16y8 and im still blowing white smoke. I bought some engine flush and refilled with fresh oil, still blowing white smoke! Is it possible there is still some coolant in the oil pan? Might need to drop it and clean it out good? Any suggestions?
Tia!</TD></TR></TABLE>
there shouldnt be unless you have a leak somewhere. Have you notice any places where coolant shouldnt be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic97b18csi »</TD></TR><TR><TD CLASS="quote">I've had it with this car! </TD></TR></TABLE>
yeah, I feel your pain. Im having problems with my b18c too. anyway, you might just have some residue left in the exhaust pipe and that is why your still blowing white smoke. Is the car overheating?
Re: White Smoke :/ (EM1b18cR)
Car is not overheating, When i start it up and its idle no white smoke if i give it some gas it starts to smoke some. When i took it around the block it was smokin pretty good.
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic97b18csi »</TD></TR><TR><TD CLASS="quote">Car is not overheating, When i start it up and its idle no white smoke if i give it some gas it starts to smoke some. When i took it around the block it was smokin pretty good. </TD></TR></TABLE>
hm.....weird
hm.....weird
Sure you installed everything ok?
This may seem like a stupid line of advice, but you're still leaking some coolant into the combustion chamber.. make sure the head is torqued on there at proper spec.
Worst case is a cracked block but that's rare.
