AGAIN FUCKING THEVES
AGAIN ******* THEVES
my friends eg got stolen 2 nights ago in front of his house and everyone is telling us that they used a "slim jim " on his car first of all when they told me this i thought of food(that was a joke) second of asll what the hell is that and third of all is there anyway of putting some kind of system on your car that would prevent the so called slim jim from working
1 Post
"slim jim" is some kind of long thing metal tool used to unlock doors from the outside. Yes, there is a way to prevent it, you gotta take apart your door and put something that will block your locks.
Re: (swatdog)
I put a long bar throught the front wheels and there is no way that you can not make noise if you want to get it out and it'll make noise and I will wake up and you have to deal with a 2nd blackbelt out /a trained boxer when I run out there so ( your fucked homey)
sorry to hear you got your stuff jacked
Re: (allmtrwhore2)
if a theif knows what their doing they can slim jim in under 16secs. I worked at a car lot and we had a repo ford taurus. My first time i had the door open in less then a min. I like the idea of the metal rod, but what if you forget you put it there??
at the jetties fishin'
Re: (dpw41285)
slim jim is a 1/16" thick yet 3' long and 1" wide metal rod with an upped edge at the lower end which will catch on the lock rod at the door latch assembly.
people say to protect against it by taking your panel off and putting a tube, etc around the door rods, etc so the tube is too big for the upped edge to grab on to.
too bad this doesnt do ****. they will just slim jim around the latch until they hook it just right and pop the door anyway, only way to get around this is to get some of that plumbing **** "great stuff" and spray it all around the latch assembly inside the door and work the locks and door handle as it dries...
just hope you dont have to gut your door and swap anything when you wreck the car is all cause you wont get that stuff off once it hardens...bright side...slim jim wont be able to chip it off etc to get at the lock rod at the latch assembly and will still have full travel...
Re: AGAIN ******* THEVES (dirtyapes)
the plumming idea sounds good but what if it harrdens to the point where i cant even unlock myself. thatnks for all ther help good thing that came out of this is my friend had just bought a K20a and was getting ready too swap it in today. but even if you have like a clifford alamr of some kind it still wont help
Re: AGAIN ******* THEVES (diearzte2)
uhhhhhhhh.... ill try that but installing a alarm system wont help cause my friend had the some kind of stoclk alarm on his car and he said he heard nothing
you can prevent the theives from using the slim jim all you want...they can still pry your windows and reach in and open the lock from the inside. that's what they did with my car 2 times now!! the window will flex to a certain point allowing a person to reach in and open the door from the inside. i didn't believe this either when i was told by the cop who found my car stripped, but i tried it since my car was already just a shell...and to my astonishment it worked!
Re: (h22ame)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22ame »</TD></TR><TR><TD CLASS="quote">but a boot or a bar on it...that bitch won't be going newhere then</TD></TR></TABLE>
are you kidding me? there's tricks, i've seen those things taken apart in a matter of seconds.
this is off topic, but i recently remove my door locks from the inside.. i can still use my key to open from the outside, but the inside locks are removed. would ppl still be able to slim jim my door??
Re: AGAIN ******* THEVES (JDMisGOOD)
there was a write up a while ago about puttin a deadbolt that goes from the door into the body of the car by remote. i cant find it tho
Re: AGAIN ******* THEVES (GoT HaTcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoT HaTcH »</TD></TR><TR><TD CLASS="quote">there was a write up a while ago about puttin a deadbolt that goes from the door into the body of the car by remote. i cant find it tho </TD></TR></TABLE>
it was just posted above..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=162718 </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoT HaTcH »</TD></TR><TR><TD CLASS="quote">there was a write up a while ago about puttin a deadbolt that goes from the door into the body of the car by remote. i cant find it tho </TD></TR></TABLE> even so all they have to do is bust your sunroof or window...
Get a good alarm with a back up battery with sensors on the windows, doors, hood etc. Hook up the club on the steering wheel with the clutch pedal Club as well. Get the shifter security as well. A thief will probably take one look at your car and quickly move on! Hahah suckers!
Re: AGAIN ******* THEVES (Spartanic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spartanic »</TD></TR><TR><TD CLASS="quote">Get a good alarm with a back up battery with sensors on the windows, doors, hood etc. Hook up the club on the steering wheel with the clutch pedal Club as well. Get the shifter security as well. A thief will probably take one look at your car and quickly move on! Hahah suckers!</TD></TR></TABLE>
unless they're driving a tow truck
