Did a Compression test on the B16*Woot Wott*
COmming up is a Race/car show event called CMI and ive been thinking of running a zex kit just to have fun at the track, so first thing i did was went out and bought a Compression tester ($24.99). Then got home and got to work. Overall i think the results came out alright.
Spec:1998 Jdm b16a Motor
Reading(from left to right cylinders)
Cylinder #1-230psi
Cylinder #2-210psi
Cylinder #3-210psi
Cylinder #4-220psi
Reason I did the test was #1. Cause i drive the car alot and floor it every now and then #2. To check if its safe to go and run the 50shot Zex kit. and #3. Cause its good to know how well your motor is running and if theres any possible problems that i should be aware of.
A problem that had me freaking out was the compression tester came with 2 adapters and i had to use the second one to screw on the cylinder head. WEll after testing cylinder #1 i go and unscrew the hose and the frekin adapter is still screwed on the head After trying to take it out i had no luck so i grab a Mocha Frapuccino and grab a tad bit of thread lock and rescrew the hose on the adapter, then finished the MOcha Frap. and gave it a try, BAMM it comes out Overall it was a fun test and recommend it to everyone out there
Cylinder #1-230psi
Cylinder #2-210psi
Cylinder #3-210psi
Cylinder #4-220psi
Re: Did a Compression test on the B16*Woot Wott* (sleepingeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingeg6 »</TD></TR><TR><TD CLASS="quote">
A problem that had me freaking out was the compression tester came with 2 adapters and i had to use the second one to screw on the cylinder head. WEll after testing cylinder #1 i go and unscrew the hose and the frekin adapter is still screwed on the head After trying to take it out i had no luck so i grab a Mocha Frapuccino and grab a tad bit of thread lock and rescrew the hose on the adapter, then finished the MOcha Frap. and gave it a try, BAMM it comes out Overall it was a fun test and recommend it to everyone out there </TD></TR></TABLE>
LOL, I did the same thing before.
Re: Did a Compression test on the B16*Woot Wott* (pakman2002)
you should be fine running the shot good numbers just take it easy with the shot and make sure not to over rev ( that's how i blew my motor) good luck at the track
Re: Did a Compression test on the B16*Woot Wott* (Simple)
thanks for the replys, as for the kit i dont even got one yet ive been lookin for one in my area before the weekend, but no luck yet. i got 4 days left but always take precautions and make shure your motor is capable of handling things u put it threw, in this cause compression test
