MAP Sensor plug problem, please help!!!
Old Mar 30, 2004 | 11:44 AM
1337 Si's Avatar
Default MAP Sensor plug problem, please help!!!
OK, my problem is this: When I had the boost on my car I upgraded my MAP sensor to an AEM 3.5bar. In order to use this you have to cut the factory plug for the MAP and solder the AEM pigtail onto the stock wiring. I decided to go back to NA, and I sold the MAP sensor and the pigtail. now I have no plug to put into the stock MAP. So, what should I do? Is there anyone that can hook me up an let me buy theirs plus several inches of the wiring? If not, what year plugs and from what cars can I get what I need? Any insight and help will be helpful, thanks.
Old Apr 1, 2004 | 05:44 AM
1337 Si's Avatar
Default Re: MAP Sensor plug problem, please help!!! (Boosted Ego)
TTT Someone has to have something that can help me.
Old Apr 1, 2004 | 06:11 AM
Nextelbuddy's Avatar
first of all you didnt have to cutoff teh factory plug all you had to do was splice in the 3.5bar map sensor plug and just let you stock one hang.... but now thats too late. you can get a map sensor plug off any honda basicalyl from 88-2001. the 88-91 honda map sensor plugs are going to be a milky clear color but will still work and will probably mounted on the fire wall on cars in teh junk yard. 92 and up basically all i the saem place as your car all with grey plugs
Old Apr 1, 2004 | 06:14 AM
SuzukaBlueAP2's Avatar
What engine are we talking about here ?
Most MAP sensors are the same.
Old Apr 1, 2004 | 10:38 AM
1337 Si's Avatar
Default Re: MAP Sensor plug problem, please help!!! (ScreaminTeg)
b16a2, and I didnt do it myself. I had a shop do all my work becasue i was majorly strapped for time.
Old Apr 1, 2004 | 11:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Ego &raquo;</TD></TR><TR><TD CLASS="quote">b16a2, and I didnt do it myself. I had a shop do all my work becasue i was majorly strapped for time.</TD></TR></TABLE>
Any other B-series MAP sensor for sure will work with yours. Junkyard run maybe ?
Old Apr 1, 2004 | 11:04 AM
1337 Si's Avatar
The issue with that is there are no B-series in the junkyards around here. Trust me I have looked.
Old Apr 1, 2004 | 02:22 PM
bkblazen2003's Avatar
does your car still run without the map senor? if it does do you notice a loss of power
Old Apr 1, 2004 | 02:28 PM
toolowsol's Avatar
Default Re: MAP Sensor plug problem, please help!!! (bkblazen2003)
I have a bunch of extra honda plugs at home, I could grab you one when I go home saturday. email me at toolosol@ comcast.net if you don't find anything. I'll let you have it for $5 plus shipping. Let me know.
Old Apr 1, 2004 | 03:45 PM
1337 Si's Avatar
Default Re: MAP Sensor plug problem, please help!!! (toolowsol)
Yea, could you grab that plug plus some of the wiring? Also, could you see if you have the intake air temp plug and wiring? That is gone on my harness as well, Thanks.
XxRoCkMaNxNEOxX
Sep 15, 2013 01:43 PM
oksblue
Mar 31, 2013 03:59 PM
thirsk66
Feb 5, 2011 07:21 PM
illassek9
Jul 29, 2008 11:07 AM
ebp 99 si
Jun 1, 2004 11:44 AM
