spark plug wires not fitting???
just picked up some different wires from pepboys the other day cuz i noticed my old ones weren't fitting right on top on the cylinders, not on the distributor. when i put the new ones on, they did the same thing. made sure i got the rights ones and neither of them sat all the down on top of the cylinders. i have a 94 b18c motor. anyone else have this problem??
Re: spark plug wires not fitting??? (FF:core)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FF:core »</TD></TR><TR><TD CLASS="quote">just picked up some different wires from pepboys the other day cuz i noticed my old ones weren't fitting right on top on the cylinders, not on the distributor. when i put the new ones on, they did the same thing. made sure i got the rights ones and neither of them sat all the down on top of the cylinders. i have a 94 b18c motor. anyone else have this problem??</TD></TR></TABLE>
Yeap, crappy wires. My magnecore do the same thing.
Apparently it's a common trait among aftermarket wires.
My oppinion is stock
Aftermarket ....
Aftermarket ....
if you are a honda owner there are really only two wires for you. first being oem, and second a set of ngk's.
well you can opt for the spoon wires but they are just steel braided ngk's with grounds. 250.00 worth of bling bling.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FF:core »</TD></TR><TR><TD CLASS="quote">so what does everyone think ngk or oem????</TD></TR></TABLE>
Re: spark plug wires not fitting??? (SoCaLNaTIvE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCaLNaTIvE »</TD></TR><TR><TD CLASS="quote">if you are a honda owner there are really only two wires for you. first being oem, and second a set of ngk's.
well you can opt for the spoon wires but they are just steel braided ngk's with grounds. 250.00 worth of bling bling.</TD></TR></TABLE>
Actually the ngk wires rate pretty bad. They compare to autolite plug wires. Really the only wires you should use are stock.
Re: (FF:core)
OEM is way to expensive, just get some aftermarket wires.
HOnda wanted to charge me $299 for an o2 sensor, went around the corner from them and picked one up for $60
OEM
OEM
.</TD></TR></TABLE>
beat me to it
.</TD></TR></TABLE>
beat me to it
shivic
01-04-2004 04:36 PM
