Camber Kit
Camber Kit
Do any of you guys know anything about this camber kit?
http://cgi.ebay.com/ebaymotors...33581
Re: Camber Kit (BatuKing)
Yeah I noticed that it's a bunch of spacers and some bushings, but is there anything better I can get. BTW it's a 92 CX
Re: Camber Kit (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">what about this?
http://cgi.ebay.com/ebaymotors...33581</TD></TR></TABLE>
That's basically the samething as the Progress camber kit (which I've used in the past). Works good for the price (normally $80-$110 for front & rear... rear being washers and bolts that are no longer than your stock ones). It comes with upper A arm joints that position the upper A arm out further from the body (thus fixing camber) and the same idea in the rear using the washers to push the upper arm out on the trailing arm.
You should only worry about the front kit... and just get washers for the rear. Any M10 x 1.25 bolt will work for the rear if you think your stock bolt is too short.
Re: Camber Kit (Newman)
i have a progress kit. I like it. it helped out alot. And i only paid 150 bucks, almost 1 1/2 years ago. But yeah those people that sell only the rear camber kits, just go down to home depot and buy some bolts and washers for like 5 bucks and then turn around and sell them for double. Just get a real kit.
Re: Camber Kit (Balut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Balut »</TD></TR><TR><TD CLASS="quote">i heard a lot of good things about ingalls </TD></TR></TABLE>
I heard that there kits squeak alot.
Re: (ABK)
I would just make sure you toe adjustment is correct and watch your tire wear from there. search for "4 wheel alignment" you will find a post that proves Toe is where its at.
Re: (TODAeg6)
What a hell are you talking about? My toe is fine, the camber is what is fucked up, especially in the back. I got access to alligment machine on daily basis so I think I know what I'm talking about. But which alligment kit should I get?
* B A N N E D *
Re: (ABK)
well then if youre gonna get lippy about how much you know, we wont help. theyre just trying to give you some insight. no need to get an attitude.
X-eric-X
X-eric-X
https://honda-tech.com/zerothread?id=811268
read that and then ask your self DO YOU REALLY NEED A CAMBER KIT
