Another Power Window problem...
Old 06-15-2013, 12:07 PM
2sLoJR's Avatar
Default Another Power Window problem...
Passenger side window has been not working for a bit now and I need to fix this before the summer heat really hits...Please help HT
Window is not responding to the switch no sounds, no clicking nothing. I hooked up the motor connector to my battery and the window moves up and down no problem so I thought it was my switch. I pulled one from the local junkyard and still NO GO. My thought is that maybe power isn't getting to the switch? I have a multi meter but maybe someone has a diagram that I can use to test the power window switch? Would I be looking for continuity or just voltage?
Oh and my driver side switch does work just not for the passenger side obviously and the lock switch is NOT on Iv'e already checked that as Iv'e seen a lot of people on here run into that problem.
Any input is appreciated. Thankyou.
95 Civic coupe ex
Old 06-15-2013, 12:15 PM
danvhp's Avatar
Default Re: Another Power Window problem...
I ran to the local library where they have AllData car repair info on line at the computer terminals. I printed out the power window electrical diagrams for 40 cents.
Old 06-15-2013, 12:25 PM
Toofpik's Avatar
Did u check the fuses?
Old 06-15-2013, 12:51 PM
2sLoJR's Avatar
Yea, maybe I'll run to the library and see if I can get ahold of some then, thanks.
Yes, checked all my fuses. Im gunna go back out with my multimeter this time and test them all.
Old 06-15-2013, 02:42 PM
n/a2boost's Avatar
Check the plug in between the door and chassis. Look for a bad connection,broken wire. Look at both door plugs.
Old 06-16-2013, 09:36 PM
2sLoJR's Avatar
Not quite sure which plug your talking about?
Old 06-16-2013, 09:37 PM
2sLoJR's Avatar
bump...
Old 06-16-2013, 09:52 PM
n/a2boost's Avatar
Old 06-16-2013, 10:32 PM
2sLoJR's Avatar
Ohhh, okay. I'll pop the fenders off tomorrow and check em' out. Thank you sir, keep ya posted hopefully I can find the culprit.
Old 06-23-2013, 12:27 PM
2sLoJR's Avatar
Doesn't seem like there's any broken wires in the plugs between the door and chassis. Everything seems normal, anyone else have any other ideas?
I know its not the motor/regulator those check out fine and my fuses are good
Old 06-23-2013, 12:34 PM
The Grumpiest
grumblemarc's Avatar
Is the condition of the wires that you posted up in the pic still the same? I don't see anything where you said you repaired that mess.
Old 06-23-2013, 01:04 PM
2sLoJR's Avatar
I believe those were n/a2 pics....Found the problem....I had no fuse in slot 8, I'm a jackass. Lol thank you for the help fellas. Moral to the story is check your fuses!!!!
Old 06-23-2013, 01:16 PM
The Grumpiest
Yeah. You're right.
Was it the fuse all this time?
Old 06-23-2013, 01:48 PM
2sLoJR's Avatar
Yea it was. I was having ignition switch issues about a year ago and I was foolin around with all of my fuses and I probably thought that that #8 slot was supposed to be blank. Lol, so glad I got this fixed.
drew and not u
06-28-2008 06:56 PM
D16Z6_turbo
08-04-2005 09:21 PM
khunt0012
09-09-2004 05:12 PM
TheIntegraGuy
05-15-2003 06:18 AM
Quick Reply: Another Power Window problem...
