suspension improvement
Currently running just skunk2 lowering springs on a 93 eg and the ride is terrible the smallest divet in the road is felt. I just came into 400 bucks and im wondering what can i do with that to make the ride better. Thanks
Re: suspension improvement
For anything else, the answer is "Save another $600, then do it properly. If you need help deciding how to do that, at least provide some information for people to use.".
Yeah... what B_swapped said. Too low of a drop for stock shocks.
If you're going to drop it that low, upgrade your shocks.
I personally would NOT lower a car with out upgrading your shocks, but there are those who have done it and had decent ride quality.
Check out Tein Lowering springs. 1.9/1.7 inch drop if you insist on keeping your stock shocks....
What do you intend to do with the car?
Road conditions in your normally driven areas?
Desired ride height?
Personal tolerance for suspension stiffness?
Personal preferences for shock damping characteristics?
Intended driving characteristics?
Other suspension modifications done on the car?
etc...
What you should do is go back to stock. All you've stated is that you don't like the ride quality. Stock will be the "best" ride quality (for the average driver, which we have to assume you are since no other information was provided). If that isn't what you actually want, then actually provide information on what you do want.
Car is a dd and dont plan on taking it to the track
Driving conditions are toronto streeets which are terrible
2" drop is what i have and would like to keep it
Would like it to be not so stiff so i dont feel every bump and crack in the road
Driving characteristics are average the random highway pulls and the odd launch no highspeed turns
No other suspension mods other than gettin a set of lcas
Two inch drop but comfortable and on a budget..........
You can have two of those.....but not all threee...sorry.
Ifyou skip the budget part get koni yellows, some extended top hats and a set of 350 lb springs from gc, 8 inch.
i threw my skunk2 springs away and installed ST suspensions 2" drop springs with kyb gr-2's and my ride quality is excellent and 5x better than s2
And honestly, GC sleeves, Koni Sports (Yellows), and a pair of extended upper shock mounts is a budget suspension. There's cheap ****, which you can get for under $600, budget suspensions around the $800 - $1500 range, and then the good but expensive stuff above that...
I see so i guess il be saving next paycheck and grabbin a set of koni yellows. I recently got an alignment like two weeks ago.
After installin the new setup would it be best to get another alignment or is it not needed
