Codes 14 and 17 '99 Civic
CEL is ON throwing codes 14 and 17 Speedo Gauge doesnt Move when accelerating.. Idle Fluctuates, Bled coolant for 30 mins.. '99 Civic Manual Trans upon releasing the clutch on first and second gear, it fluctuates as it accelerates so i have to rev high and start to release the clutch complete for a smooth take off.. any idea?
Re: Codes 14 and 17 '99 Civic
BUMP Update. further testing, clutch has nothing to do with the surging.. Gas pedal pressed slighty causes the the engine to bog.. like its about to stall, so i have to give it more gas.. Throttle body cleaned, IACV cleaned. FIA Reconnect (was DC before and was running fine[could cause the boggs?])
II. as i was checking everything, i raised the car and shifted to 1st and noticed that my Right(Passenger) Wheel doesnt turn/run with the Left(Driver) Wheel.. any idea whats causing this? and could this contribute to my VSS not working?
1) Use a code reader to pull the OBD2 codes, which will provide more detail about the code 14/idle problem.
2) Code 17 -- Check the VSS connector for voltage and ground. Also check 7.5A dash fuse 15.
ill try to pull the code with a reader. the last time i used it, it did not show any codes. ill check VSS wiring.. fuse 15 underhood is ok. thanks
calvin924597
25
01-10-2014 06:37 PM
Hmotoredcoupe
04-14-2013 07:41 PM
