Possible spun bearing??
Does this sound like a spun bearing? 98 civic auto (80105 miles), Never low on oil or over revved...
I had a engine rattle that I asked about just under 1 month ago. It was suggested to do a valve lash adjustment. I messed up on the mm & inches because of so much stress in terms of my health.I couldn't find .20 & .25mm on the feeler gauge I bought,As I didnt read the package fully. Anyway I ended up using .020 & .025 inches twice and hella lot of noise came with that.
I looked at my manual and saw my specs were very wrong. I seafoam my car through the brake booster vacuum last night at 3000 rpm. About half of a 8oz cup. Revved it up to 6k rpm on/off, no further to get the smoke out after the 10 minutes then drove it 22 miles spiritedly ( never went over 4.5k rpm ) and started it today & heard the noise like a loose part. The valve lash is fixed to spec. now (no noise) but that loose part is still there like below my intake manifod or close by.
Re: Possible spun bearing??
That's your valves man the valve lash should be 0.007" on intake and 0.009 on exhaust if u had a spun bearing u would loose oil pressure and stall out
Manual says .007 -.009 inch Intake. Exhaust : .009 -.011inches
It only stalled once at idle. And I drove it after restarting,it's been hesitating quite a bit since I put it back on the road with idle surge then it picked up and vtec kicked in. It's been sitting 1 and half years.
I know I have a possible bad iacv. It sputters & rpms drop to 0 every second but smooth out when warm & drops in gear again but I'm worried about the sound at 8 and 21seconds in the video.
take big very solid screwdriver and put the tip on each header runner and put ur ear up to the handle and listen as u rev it up and see if u hear any clanking in the bottom end.... ive done this for years and have determine knocks in specific cylinders before disassembly... a poor mans stethoscope... you can move the tip of the screwdriver around (valve cover, intake...etc..) and listen around the motor where ever u are... I know the headers a good spot for the noise to echo in the chamber...
Spun bearing will not make you stall out until after you break a rod. Please don't spread false information. OP that def sounds like its coming from the head. Recheck the valve clearances.
All I did was run 5 ounces of seafoam slowly through BBV hose then after 10 minutes started it, revved to like probably 5 or 6k just a couple of times. & like 3.5 until the smoke died out somewhat. Loud valve tick was still there when I took it for a spirited drive but we never passed 4000 rpm or hear any knocking.
I was ashamed of myself when I realize by adjusting them 0.025 and 0.020 it sounded worse.
It's my fault though,never read the package carefully to see the measurements. I did that setting twice and was wondering why the hell is it louder than when I had the last summer parked.
I did adjust it back to .008 and .010 but that wasn't good enough apparently. I bought a gauge with the specific honda requirements and did it over last night. Haven't started the car since.
Shows how much u know about engines 98ekb18c
