My acceleration is hessitating
Old 06-23-2013, 10:35 AM
Marcosdlt's Avatar
Default My acceleration is hessitating
Ok I have a 96 Honda civic ex model and it doesn't keep the acceleration once it hits op. temp. The engine light is on but I no it's for the knock sensor it needs to be replaced. I have changed the timing belt, valve cover gasket and all the seals, changed the distributor cap and rotor, new plugs and plug wires I'm about to change the idler pulley,.... I'm wondering if it could be my valves or pistons cuz it wasn't doing it before my timing belt snapped while I was driving on the freeway after I put the timing belt on it started losing acceleration........does anybody have an answer cuz I don't want to run and jus start fixing whatever and not fix the problem
Old 06-23-2013, 10:50 AM
doublezerohatch's Avatar
Default Re: My acceleration is hessitating
You own a civic, it never had any acceleration . . . how can you lose something you never had !
Old 06-23-2013, 11:00 AM
B_Swapped93's Avatar
well if it snapped while you were at highway speed im willing to bet bent valves you can do a compression/leakdown test to figure out weather or not that's it. clean the TB while you're at it.
Old 06-23-2013, 02:16 PM
fragmare's Avatar
Yea, make sure your valves aren't bent. That's always a big possibility when a timing belt snaps. Also, have you checked the throttle cable for slack? That can be a major culprit for hesitating acceleration. Easy to fix too.
Old 06-23-2013, 02:27 PM
Dude .. its a civic . . . it never had acceleration . . this guy cant be missing something he NEVER had . . if a stock civic lost acceleration it would be going backwards . . .
This is all there good for . . .. .
Old 06-23-2013, 04:06 PM
Lizardslap's Avatar
is that a beer in the cupholder I see there lol
calibrate your tps it wont be faster but you will fix the throttle response pretty good
https://honda-tech.com/forums/tech-misc-15/diy-how-calibrating-voltage-your-tps-sensor-2947986/
Old 06-23-2013, 08:55 PM
jbpnoman's Avatar
doublezero, if you aren't going to be helpful, go away. We don't need you filling threads with garbage.
OP, pull your CEL codes again to make sure that's the only code you have. While you're doing that, check your mechanical and ignition timing, and make sure your TPS is within spec.
Atauto
Honda CR-V & Element
04-27-2015 02:06 AM
bobbed shadow
Honda Civic (2001 - 2005)
10-13-2011 05:24 PM
Sonsrox
41
09-15-2009 11:53 AM
aznxpyroboi
12-11-2007 11:23 AM
CLICC916
07-23-2001 09:11 PM
Quick Reply: My acceleration is hessitating
