Distributor question on a d series.
So i bought a 93 del sol for teh lows. It came with a d15z1 that came from a vx, my question is could i use a distributor from any other d series? Thanks in advanced.
Re: Distributor question on a d series.
I do not know yet. I bought the car as a shell and just recently dropped the motor in, I dont have the ditributor and other misc parts to start it. I was just wondering before I purchase the part if I can get away with using another distributor.
Just replace it icm and the ignition coil in your current distributor with any d series b series all honda acura distributor internals are the same
Its an si, so all it had before was the original motor.
My problem is not having any type of distributor on the motor currently, Im trying to take the economical route and find one that can work.
Technical Hero
92-95 D16Z6 is the only other one that will bolt up perfectly. However the Z1 in that car is going to cause you a ton of wiring headaches if you attempt to run it on the stock ECU.
ferio-ichi3
17
11-05-2015 12:11 PM
raidacaipo
05-24-2009 09:28 AM
