HELP! Foglight Switch Wiring
recently got my foglight all set up in my ek, ran into little problem with getting a led on the foglight switch to light, was hoping you guys could spot what im doing wrong and correct this and get it working. switch was from radioshack.
led switch
http://www.radioshack.com/product/in...ductId=3159591
packaging diagram
current wiring setup
thank you!
led switch
packaging diagram
thank you!
Re: HELP! Foglight Switch Wiring
that red wire it looks like your have a ? mark is the power to the indicator light. Just wire that to the load to the foglight. or a positive source
looks like you have a BASIC light up switch...
just wire the random wire you don't know where it goes to, to your load on the (1) side. the load from the switch to the relay, just connect it somewhere to that wire. (I suggest heat shurnk butt connectors)
edit: the only reason theres a ground to the switch is because it has a light. the 2 random wires that are not loads are the light wires.
