error code 12 EGR on a d16z6??
Old 06-26-2013, 01:01 PM
waynesumner's Avatar
Default error code 12 EGR on a d16z6??
i pulled an erroe code 12 and 3 on my d16 i now know the d16 doesnt have an EGR so would i be getting this code? could it be mistaken as 3? my check engine light blinks very dim and its hard to tell whether it pauses or just keeps blinkin. my SRS light stays blinking while running the codes? any ideas?
Old 06-26-2013, 01:44 PM
The Grumpiest
grumblemarc's Avatar
Default Re: error code 12 EGR on a d16z6??
Why do you keep starting new threads for ongoing issues for the same unfolding problem? This is at least 3 now.
Maybe you should have posted a video.
Old 06-26-2013, 02:26 PM
its not the same issue its an error code i got since i actualy got my car started! i havent said any thing about a distributor or getting spark from a distributor or timing a distributor sure its my fault i have issues with my car i would like to get sorted out so why dont you buzz off and do what you do. if you dont have a solution dont imply your opinion. or if you do have a solution and would like to be so kind and give your opinion please do but i suppose i already know your opinion it would go something like.......... quit starting threads about the same issue your flooding the forum.
Old 06-26-2013, 02:29 PM
FAMz_DOMANi_MB4's Avatar
simplex ur ecu might be a for d15z1 cause vx has egr but has vtec done deal find urself a p28 ecu and stop making extra threads thank you
Old 06-26-2013, 02:34 PM
well how do you find out what ecu you have and how am i supposed to figure out anything if i cant start new threads about it. isnt posting threads what a forum is for? to help people or get help with problems that arrise one after another. nobody is going to look at a thread that has already been delt with or doesnt have anything to do with a new problem.
Old 06-26-2013, 02:40 PM
whats your ecu code?
and befor i switched out my HARNESS and DISTRIBUTOR i never had a CEL i never changed my ECU and all the connections are wired back how they were. plus the harness i got off of a d15 most likely didnt have an EGR and i know forsure didnt have VTEC because i had to wire VTEC myself
Old 06-26-2013, 02:41 PM
and again whats your ecu code?
Old 06-26-2013, 02:47 PM
37820-p06-L51
743610145
now i assume its a p06 due to the middle of the code up top. idk because i didnt install it.
Old 06-26-2013, 02:49 PM
looks like something gone wrong with your p28 converted ecu
Old 06-26-2013, 02:52 PM
ya it came out of a civic dx says a thread i came upon. now would it matter though?
Old 06-26-2013, 04:32 PM
The Grumpiest
Since it is becoming extremely evident you are less than knowledgeable about your car than you should be, how about post a video so we can see what codes are being thrown?
This thread is just another part stemming from the original issue you posted about your car. The last two threads were about the distributor issue and car not starting which you claimed were BOTH caused because of an o-ring.
The core issue was that you somehow set your car on fire and EVERY issue you've had since then stems from poor attempts to fix the damage.
Only one damn thread was ever needed.
Old 06-26-2013, 05:33 PM
no first i wasnt getting spark then then the spark plug wires were wrong then it was the o ring. lol it dont even matter anymore im trying to get the video up right now so keep your eye out.
Old 06-26-2013, 06:05 PM
The Grumpiest
And all of that because your car caught fire.
Now put the video up.
Old 06-26-2013, 06:27 PM
B_Swapped93's Avatar
lol^
but OP seriously you could have just kept updating your original thread and bumping if needed.
Old 06-26-2013, 07:05 PM
I've done worse. I cant get the video uploaded ill keep trying but its a 3 manifold absolute pressure sensor and I cleaned the map sensor but it still shows up maybe its the #2 oxygen sensor but I only have one oxygen sensor and its on the header
Old 06-26-2013, 07:15 PM
its on youtube, jump ahead to 9 seconds and youll get a better look at the code.
Old 06-26-2013, 07:33 PM
are you using the correct ECU ?
Old 06-26-2013, 07:42 PM
p06 from a 92-95 dx. I know its supposed to be a p28 but before all this occurred I never had a CEL and its all the same beside the harness and dizzy and its all wired up the same, is the SRS supposed to be going off like that?
stopltracr
01-25-2016 04:35 PM
turboblack2door
09-02-2008 01:10 AM
HA0LEFIED
12-13-2006 04:04 AM
kamakaze1
07-28-2006 11:06 AM
omgwtfhaxnub
04-12-2006 10:26 PM
Quick Reply: error code 12 EGR on a d16z6??
