Speed Sensor?
Speed Sensor?
Hello guys. I was directed to post on here for my problem. I've been driving a 98 civic DX sedan for 5 years now with little to no problems. Today while driving my speedometer started going up and down drastically when I accelerated. Like 0-80 when I just tap it then it kinda flutters about and drops down to 0 after I let it idle. The check engine light came on as well. On top of all of this my car won't go past first gear or so it seems. I was told its probably a speed sensor on my transmission but I was wondering if anyone has experienced anything similar. Any information at all would be greatly appreciated!
Thanks!
Thanks!
Re: Speed Sensor?
post the code. so when you hit(tap) the vss it works ?. check the plug(s) on the harness and the vss it's self for any loose wires/corrosion. if they are both find you may need a new vss which can be got at a pick n pull for 10-20$. but the vss going out would not cause the car tp not go past first as you say. is this an auto ?
Mauro87
13
07-15-2012 05:16 AM
silentblackhat
12-25-2005 05:29 PM
